My impression so far is that regulating is a just a question of setting the watch to go faster or slower, whereas adjusting is more involved and concerned with getting the watch to run as consistently as possible (in all positions). Is that about right?
What's all this about adjusted in 5 positions though? I understand the different positions (face up, crown up etc) but there aren't different adjustment possibilities for each position, are there? (Orthogonality in physics/maths terms :) , ie. where adjusting something in one position doesn't affect the timing in the other positions)
What can one do, apart from get the balance wheel as perfectly balanced as possible, the balance spring shaped properly and the end gaps in the studs (?) set properly?
This isn't about a problem with a particular watch, just general curiosity.
Edited by colinh
This is an interesting question which, appart from the intrinsic build/design of the movement might have to do to what we hobbyists and watchmakers do "at the shop" with the timegrapher.
As per watchmaker's class:
" Different watch companies may adjust to different sets of positions, but the following are common:
1 position adjustment: DU (dial up) This watch can be said to be only regulated!
2 position adjustment: DU and PD (crown down)
3 position adjustment: DU, DD (dial down), PD
4 position adjustment: DU, DD, PD, PR (crown right, vertical position)
5 position adjustment: DU, DD, PD, PR, PL (crown left, vertical position)
6 position adjustment: add PU (crown up) to the above positions. Six position adjustments are difficult!
First: equalize the horizontal positions: Rate difference between DU and DD can usually be attributed to differing friction in the two positions. Check pivots, jewels, lubrication, and rubbing of balance wheel or hairspring in one position but not the other.
Second: equalize the vertical positions: Differing rates in the vertical positions are caused by the effects of gravity on the balance complete. Errors are caused by an out of poise balance wheel or a hairspring that has been deformed from its ideal shape.
Third: equalize the horizontal and vertical positions: Very slight opening or closing of the regulator pins may be attempted. Careful so the pins don't pinch the hairspring.
Rules:
1. Opening the distance between the regulator pins and hairspring slows the rates in all positions. But, the vertical position (crown down) is affected more than the horizontal (dial up/dial down).
2. Closing the distance between the regulator pins and the hairspring speeds the rate in all positions. But the vertical (crown down) is affected more than the horizontal (dial up/dial down).
When all the rates are as close as possible, the regulator can be used so that all or most of the rates show a slight gain. If the actual wearing conditions cause the watch to gain or lose, the regulator can be used to achieve a rate to match the wearing conditions. This is sometimes called “adjusting to the wrist.”
Once the watch is regulated for position, carefully replace the winding rotor. A careless bump against the regulator or the stud when installing the rotor can affect the timing. Once the watch has the case back on, recheck the timing again."
So that's all there is to it, easy as pie!
    • Alex mentions the coils below the stud should remain the same as you move the regulator block along the terminal curve.  Mine do that. What he doesn’t discuss and is used in the other video is how the regulator block is used to adjust rate and positional error.  He also doesn’t mention how opening and closing the pins could and in my case does, alter amplitude  In Alex’s video once he sets the stud he never adjusts the regulator pins yet every new movement I get have the pins signing closed.
    • The video I linked above does mention the spacing of the hairspring coils, and the importance of the regulator being able to move through its full range without distorting the hairspring - the terminal curve of the hairspring must be concentric with the regulator pins throughout the regulator’s range.  If you meticulously follow every step in this video, the regulator system should behave as intended, regardless of the brand of the movement.  Best Regards, Mark
    • Hi friends! My mother got a bunch of old watches from a horologist who was retiring, and he subsequently passed away. It's been in her studio for years, and she showed it to me today and I just fell in love with it. Sadly, I don't know a darn thing about it yet. It's quite old, or at least seems to be. It has two winding arbors, but the key is missing. The crystal appears to be some kind of yellowed plastic, which is odd- I think it was replaced at some point to possibly protect it or something. If I had to guess, it's from the mid-19th century, given that it has no keyless works and that it says "Anchor Escapement" in French. It looks to be about 18 ligne, and the case fob is positioned in the upper right corner. The face is missing the dial, the hands, and a couple of the wheels that drive the hands- I think. But the movement itself seems to be in excellent shape. The serial number on the movement matches the number on the case- it's stamped on the movement and on the case in two places. I haven't started any disassembly yet, but I'm wondering if anyone can give me some idea of what kind of movement it is, and where I might look to see what parts are missing from the face. i may even have a dial that would fit it. It's in good enough shape that I think I could get it running, assuming I could find the missing parts. Any insights are vastly appreciated and thank you! Addendum: The inside of the case has some *very* tiny scratched numbers and letters in it, but I am having an extremely hard time seeing what they are. Like "N 99" and "No192X", They were clearly done with some kind of sharp stylus and maybe they mean when it was serviced or by who? Addendum the second: At least one of the scratches seems to say "N1921X" or maybe "W1921X". Serviced in 1921? And the inside lid of the case has the letters R H with a star between them, and a very tiny mark that says "ARGENT" in a u-shape.
    • I’ve watched every video I can find on YouTube. Some of the info is contradictory and none mention  the effect on amplitude or spring coil spacing which I observed. I was hoping someone here is a Seiko expert and knows these inside out.
    • This video explains how to set up and adjust the etachron regulator :   I hope that helps, Mark
