Hello all. I searched for a topic on junk evaluation, but could find none.
I just joined Mark’s course, and in the excitement of learning, asked a local watch repairer for a few junk movements, so I could practise a bit before receiving my chinese clone. But to my surprise, i got two working watches, and some fancy junk. My question regards the memosail, the working ones and the pocket omega. Is it possible that the repairer gave something he should keep? Should I return these?
The list:
VIP memosail 17 jewels
Citizen cronograph automatic 23 jewels
Omega pocket
Working movements:
Vedeor 17 rubis incabloc (nothing on google)
The list:
Omega pocket
Working movements:
Orient automatic 21 jewels ee599c05f6de0a1b0ea40ab6766b0fad.jpg&key=07500ec76fd47f5bae6e16a40a445463eceb04990984b18d3131e90fbafe1c9e
The memosail is a high-end watch and some parts are not available. the dial and hands will probably be of value to someone.
The omega pocketwatch is nice but they're not really worth big bucks. They dont have balance protection so the balance is probably broken.
I would save the citizen for late once you've gotten some practice on simpler stuff.
The Orient is a good starter watch.. better than most chinese clones.
Not sure of the vedeor but should have a jewelled escapement and this would be a good starter watch, especially if it has an Incabloc shockprotection.
Don't feel bad about the fact the dealer may have given you a valuable watch, he's a professional (or should be) and should know better. The usual reason for orphaned movements is 1)the shop replaced a non-runner with another working movement or 2)the case was gold and that was sold for scrap. My guess is (1) for your bare movements like the Citizen and Memosail.
Another scenario is the older watch repair guy is no longer around and the new guy has no use for these things.
My personal experience, after checking the movement of a watch that's sent to me for service, I have sometimes found that the watch is not repairable or would cost to much to repair. After telling the owner the news some have opted not to repair but have later come back after having sourced a similar watch/movement and requested me to do the transplant. They usually have no interest in the original unusable movement so it goes in my part stash.
Good luck and have fun!
Anilv
Anilv
Thank you Anilv. I took your advice and started with the orient. It is funny how monstrous the eta 6497 look in comparison.
Having a lot of fun. Nothing lost or broken yet.:)
I agree regarding that Memosail. Very cool piece that I’d like to add to my collection some day. Parts are quite hard to get but there are plenty of good runners out there. I’d hold that I reserve with The chronograph for later.
    • Decided to update with the repaired watch back in rotation and the new anniversary gift.
    • I’ve been playing with a NH35 movement that which has the classic Etachron regulation system and a few balance assemblies as practice. What I’m trying to do is get comfortable with the effect both the stud and regulator pin positions have on rate and positional error. When I install a new balance assembly I install it with the assembly in place  on the cock and cock is attached to base plate. I use the back of the tweezers to push the stud into place and feel the click. However, I noticed that the angle of the stud can be adjusted and what I also noticed is that some movements have the stud carrier arm bent down a little and that changes the angle of the hairspring leaving the stud. This angle effects how the spring goes through the regulator pins and also the spacing of the coils opposite the stud. What I thought I was supposed to do is set the regulator block in the middle of the curve, open the pins, and use the stud angle to center the spring.  Then the stud is set.  Now on all the new NH movements I have seen the angle of the regulator block is about 60 degrees counter clockwise from full open. I watched a video where the author used the regulator pin adjust to adjust rate and position error. When I close down the pins I do notice that the rate increases but also the amplitude drops, the coil spacing changes and hairspring appears slight straighter between the stud and the regulator block. If I open the pins the amplitude comes back, the spring breathes a bit more between the stud and the regulator block and the rate slows.  So, a long post I know but I would really appreciate any advice on how to correctly adjust the etachron system for rate, amplitude and positional error.
    • Aw come on Andy, it was just a comparison between spending 30 quid and tackling a tricky piece of work. You appeared to be volunteering,  i volunteer for stuff all the time it gets me into all kinds of trouble.
    • It's not really shown here , but the blade flips over, so it faces the other way. The knob and threaded case holder then pushes the caseback seam into the blade. Once the blade starts to penetrate into it, the lever and blade are lifted , which should hopefully pop the back off. A lot of fashion style cases have very tight seams and need a sharp blade to start separating them.  Don't buy the cheaper plastic versions of this tool, the posts with the pins through for blade holder break easily if the apply extra force to blade.
    • You will still be looking for a balance complete I’m afraid, this is the balance staff, balance wheel and hairspring in one package. Hairspring and the balance wheel are matched in the factory. Whilst we can change a balance staff the hairspring and balance wheel stay together.   Tom
