Another clock Quiz
oldhippy
What is wrong with this. It happenes a lot with very old clocks. There is something major.
There are a few bits missing but that is not the quiz.
Is the spring barrel being held together by wire. Very dangerous.
I can see that the back cock ( I think that is the term ) is upside down. I think this would suggest wear on the escapement and the drop on the anchor has had to be adjusted and the only way to do it has been to turn the back cock upside down.
If I'm close then, and the clock has had a major change, it never started life as a anchor escapement  the alterations are crude there are holes in the plate and the back cock is upside down so never belonged to the clock in the first place .
Well its a bracket clock movement do longcase clock pillars and bracket clock pillars correspond in style and date ? if so this clock judging from pillar style would be about 1660 to 1740 because the pillars are "Finned" ?
The clock must be rack striking because there is no evidence of an outside count wheel so that would put the clock to 1680 to 1740, the anchor escapement didnt start appearing in bracket clocks until the 1780's onward, so from date alone I would say the clock was originally a verge that has been converted to a anchor escapement because from 1660 to 1750 the verge was the dominant form of escapement in bracket clocks.
Spot on and well researched.  The conversion is very crude.
The other thing that stood out a mile is the so-called pattern that the back plate has. That has been added at a later date, I expect it was added at the same time that converting it to an anchor escapement happened.
Fusee clocks, Many run by a chain, they also have steel wire, bronze wire or gut. You might think they look dangerous, but they are quite safe.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
