I have this ETA 2892 chronograph for service. Service went well, everything functional.
However when I mount the base movement to the module, amplitude shoots down to around 160 degrees and timekeeping is sporadic.
I can't find a tech sheet for the module ("shouldn't be serviced") and no troubleshooting issues. I watched the video about the Breitling chrono service and didn't see anything I haven't already tried.
Any help would be appreciated. My first thought is the chronograph is partially activated when its mounted somehow, but I'm still at a loss.
I think I have one for the Omega 3220... That's basically the same movement.  Will send it to you later when I get back to my laptop.
Anilv
This may be of use, i have a 1138 that is currently in pieces waiting for me to start working on.  have you serviced the DD module aswell as the movement?
231_Omega3220.pdf
Had big problems with a Heuer with a  ETA quartz on top that i tried to service . Had to give up . The DD unit is very hard to service . And you need to get the right amount of oil on every pivot.  BTW did you service the DD unit? If not that is probably where the problem is.
Wow, I can't thank you guys enough. A tech sheet that shows me exactly which screws go where? Perfect.
I did service the module.. I can usually determine pretty well what are bearing services, so I don't think my service is the issue. Plus the watch repair channel video showed me everything.
Gonna take a go at it tomorrow and make sure I didn't miss a pivot.
    • By the way, I opened my watch, looked under a magnifying glass, there is simply no grease, the screws are without traces, the slots are intact.I think it's just a matter of maintenance.there are no rotor marks on the body. And to remove the strap from yours, just press on the 1st side,and slightly move the strap, then on the other side and it will come off.
    • Hi My name is Chris. Just started trying to learn about watch and clock repair as a result of repairing my fathers old 1890s police station clock (about a year ago). The clock was Ok, but having graduated to pocket watches and then wrist watches, despite the really excellent stuff on Youtube, I am struggling a bit.  As a retired engineer, I find the engineering exquisite, but a bit on the fiddly side.  I have done a few practice watches with a little success but failed a few, but have had success with Seiko 7005s, 7009s etc, but have just attempted a citizen 5430.  Nightmare.  My wife thought I had found religion as I spent so much time on my knees with my eyes to the floor looking for springs.  Got through that and found that the balance is shot.  Trying to source one or something that will fit from the citizen range has me totally perplexed.  Tried Ebay, Cousins etc without luck.  Any advice as to alternatives that will fit or alternative sources would be gratefully received.
    • I have only been a member for six years & I have found this a very friendly forum although I don’t have anything to do with watches not because I don’t like watches but because I have gout in both hands so my dexterity isn’t very good, I restore torsion clocks & occasionally other antique clocks also at 72 my eyes are not what they used to be, that is why I only post on the clock forum & the lathe forum mostly . As others have said Mark it is much appreciated that  you are willing & able to do this. very many Thanks Dell
    • Ah, this is brilliant, thank you very much!
