Hi guys! I’ve just bought myself a electric watch winder & i was wondering which sort of winding settings i need to use on my seiko kinetic watch for the first time! It come with 5 program setting! Cheers!
Ha!  What a great idea!  I love kinetics but it's always a pain to keep them charged.  For me, I'd do the maximum wind until they were charged and then change them out.  Gesh, great idea!  I've been thinking too much on the mechanical side of the world.  :)  Now we just need ones that turn lights on and off for the Citizen's Eco Drive.  :)
Nice one mate! I was asking more about which way to wind it really! The winders got setting on it eg clockwise rotation, anti clockwise rotation, both together & so on mate! & different timing modes!
Yes, after researching this winders really don't do well at all.  At least it's not working well with my Versa.  :(  All of that led to another search for another solution.  I see the toothbrush induction solution all over the place but that also is not working for me.  This is seriously a PITA.  If anybody has a good link or video on something that actually works it would be nice to get it posted.
Along with some specific data.  Like just exactly what model of charger are you using and how long does it take to completely charge it.  Will it even completely charge it?  How do you mount the watch on the charger?  Do you cut off the tab standing up so the watch lays flat on the base?
I had mine on over night and the charge didn't budge.  I guess the other solution would be find a continuous running winder.  Anybody have a model number?
Seiko really needs to start making their charger again.  The prices for those are nuts!  Whine, whine, whine...
Yes, after researching this winders really don't do well at all.  At least it's not working well with my Versa.  [emoji20]  All of that led to another search for another solution.  I see the toothbrush induction solution all over the place but that also is not working for me.  This is seriously a PITA.  If anybody has a good link or video on something that actually works it would be nice to get it posted.
Search for
Philips Imageo on this site or Google
    • Alex mentions the coils below the stud should remain the same as you move the regulator block along the terminal curve.  Mine do that. What he doesn’t discuss and is used in the other video is how the regulator block is used to adjust rate and positional error.  He also doesn’t mention how opening and closing the pins could and in my case does, alter amplitude  In Alex’s video once he sets the stud he never adjusts the regulator pins yet every new movement I get have the pins signing closed.
    • The video I linked above does mention the spacing of the hairspring coils, and the importance of the regulator being able to move through its full range without distorting the hairspring - the terminal curve of the hairspring must be concentric with the regulator pins throughout the regulator’s range.  If you meticulously follow every step in this video, the regulator system should behave as intended, regardless of the brand of the movement.  Best Regards, Mark
    • Hi friends! My mother got a bunch of old watches from a horologist who was retiring, and he subsequently passed away. It's been in her studio for years, and she showed it to me today and I just fell in love with it. Sadly, I don't know a darn thing about it yet. It's quite old, or at least seems to be. It has two winding arbors, but the key is missing. The crystal appears to be some kind of yellowed plastic, which is odd- I think it was replaced at some point to possibly protect it or something. If I had to guess, it's from the mid-19th century, given that it has no keyless works and that it says "Anchor Escapement" in French. It looks to be about 18 ligne, and the case fob is positioned in the upper right corner. The face is missing the dial, the hands, and a couple of the wheels that drive the hands- I think. But the movement itself seems to be in excellent shape. The serial number on the movement matches the number on the case- it's stamped on the movement and on the case in two places. I haven't started any disassembly yet, but I'm wondering if anyone can give me some idea of what kind of movement it is, and where I might look to see what parts are missing from the face. i may even have a dial that would fit it. It's in good enough shape that I think I could get it running, assuming I could find the missing parts. Any insights are vastly appreciated and thank you! Addendum: The inside of the case has some *very* tiny scratched numbers and letters in it, but I am having an extremely hard time seeing what they are. Like "N 99" and "No192X", They were clearly done with some kind of sharp stylus and maybe they mean when it was serviced or by who?
    • I’ve watched every video I can find on YouTube. Some of the info is contradictory and none mention  the effect on amplitude or spring coil spacing which I observed. I was hoping someone here is a Seiko expert and knows these inside out.
    • This video explains how to set up and adjust the etachron regulator :   I hope that helps, Mark
