I'm about to pull the trigger on Course 2 with a Unitas 6498 movement from an old Arnex pocket watch.  In the meantime, I've gotten ahead of myself with a Timex 2017 2470A watch and taken the movement out by removing the stem, hands, and face (3 tabs).  What do you all use to hold the small parts?  I'm thinking I want to keep each section of the movement in its own container, but I'm stopping now until I take the course since I'm guessing there is a specific order to disassembly, cleaning, inspection, replacement parts, reassembly, oiling, etc.  Nontheless, I need some small cups.
I like to keep associated parts together. For example a bridge and it's screws, all the train wheels, balance assembly, and keyless works parts. It makes things easier for reassembly.
At one time I used Pill Boxes which are available in most pharmacy's. However, I have switched to aluminum containers which I ordered from a watch parts supplier. They are very inexpensive. I have attached pictures. The aluminum containers have a see through cover and  fit together in a nice box so I have all the watch parts in one place.
This is what I use now.
https://www.cousinsuk.com/product/trays-watch-disassembly-assembly
Once you have got a set you will buy more. They stack so depending on what type of watch you are working on you may use 1, 2 or 3 trays or more. I do feel these are the best for storing disassembled watches, especially if you have several on the go as they stack whilst waiting on parts to arrive.
Those are nice too!
You can get these in the States from Cas-Ker (jewlerssupplies.com)
I use these two pill organizer from Dollar tree,
I use the 7 day pills on the bench and the 14 pills for spare watch parts and other small stuff.
On 1.6.2018 at 10:23 AM, oldhippy said:
This shows you how long ago back in the 70's and 80's I used this type. I bet you can't get these now.
you can get them still in all sizes. Aluminium / glass. Made in India.
Frank
On 6/1/2018 at 9:55 AM, TimFitz said:
Here are two of my 18s Pocket watch movements in themimageproxy.php?img=&key=77f0dcc5ac0f9d5b
I also use these removable labels so I don't permanently mark the trays .
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
