L&r Ultasonic Vari-Matic Re-Furbished
clockboy
Picked up my L&R re-furbished machine yesterday. It now cleans without smoke from the motor is wired safely and cleans & drys watch parts a treat.See below before & after pics.
Highly recommend Graham Baxter @ http://www.delphelectronics.co.uk. Very knowledgable guy and has an interesting site to visit.
post-234-0-78863000-1412414033_thumb.jpgpost-234-0-38138500-1412414035_thumb.jpgpost-234-0-74712600-1412414036_thumb.jpgpost-234-0-74712600-1412414036_thumb.jpgpost-234-0-92457600-1412414037_thumb.jpgpost-234-0-53944200-1412414039_thumb.jpgpost-234-0-96824100-1412414040_thumb.jpgpost-234-0-22183800-1412414042_thumb.jpg
Edited by clockboy
  • 10 years later...
20 hours ago, oldhippy said:
That is one of the watch cleaning machines I had.
A classic well-built machine that seems to last almost forever. Which is why you see people still out there using them. When I was in school we had one it worked really well. Although the downfall would be people who forget to keep the fluid level at the right level and they burn the transducer out.
This is the other auto I had before this is japanese and I got excellent results with it it has ultrasonic in the cleaning jar. You can see the ultrasonic unit on the bottom of the jar on the left and to the right of the heater a spare one.
Edited by oldhippy
Interesting about it being Japanese because? When I went back to one of the wostep reunions we were asking about the cleaning machine that the school had. Amusingly and I can't remember who made it I'm guessing Greiner we were told that it was a Japanese product and it was not reliable. What I find interesting is your machine employees similar ideas in other words square jars and the transducer goes into the bottom of the machine. The one that we had was all sealed up and would be appear to be a more modern or newer version perhaps.
I wonder what happened to the company in Japan that was making these? I was once trying to find the company because curious about their products and I couldn't find any Japanese watch cleaning machine makers. Also find it interesting in that a lot of the companies selling products don't actually make the product. This also applies to some timing machines where they were just branded even witschi allowed Elma to sell their machines with the Elma name on them in a different color the plastic case. In other words the Elma machines were blue in color. Also amusingly the Elma version of which he was usually slightly cheaper.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
