What is wrong with this movement
oldhippy
They had clocks in railway signal boxes?
I used to work for the railway in Western Australia in the comms section in all the archival books and diagrams I had access to I never saw a clock in a signalbox.
Other than a bent crutch which is not really a problem I don't know what is wrong
I do not know Kay & Co LTD so I looked them up to find out they were primarily a mail order company but did indeed win a contract to supply GWR clocks.
http://91.197.228.188/~kaysh/2017/03/16/kays-watches-and-clocks/
The fusee and barrel arbours stick too far out of the back plate they are not rounded or polished at the ends and most of the English fusee clocks I've seen would have brass washers where the screws go into the pillars to hold the plates together.
Then you are correct. The whole clock is one big fake. It was made in India, its about 15 years old, it has been aged to make it look old.  I thought the poor so-called stamp engraving and the shocking finish would have told members that no way could it be an English movement.
As the saying goes down here where I live. Its as rough as a badgers ass. :D
Like the other thread about Chinese carriages clocks, the Indians seem to specialise in fusee wall clocks and Ebay is full of them popular clocks faked by the Indians are R.A.F wall clocks and Railway clocks one of the big give aways with these clocks without having to see the movement is that they are hinged on the left hand side of the Bezel instead of the right.
I've seen plenty of fake RAF clocks but this is the first time I've heard about fake railway clocks.
Do you have a picture of what a genuine Kay & Co clock movement looks like/
When I was looking up the company yesterday I could only find pictures of the clocks showing the dial and case.
24 minutes ago, Lenj said:
Do you remember this one on Ebay?? they were a wash with these, does anyone know why? Probably obvious..Anyone remember the serial number the same on every clock..lol
Len
I would be suspicious right away. The hands are the wrong colour, the writing on the dial is not right it is not in line with 12, so I would say it’s a new dial. Hinged to the left.
Yep correct and NO Cillet Bland it was Gillet Bland..All have the same movement number and these are stamped 6472 LONDON, other characteristics are very thick glass in the cast brass bezel which normally is hinged to the left hand side....I feel that they were trying to tell us, that all their clocks were fake..
Len
Based on what I learnt on this thread I decided to play 'Spot the modern fake' with Fusee clocks.
I came up with 3 that are obviously modern (last 20 or 30 years) fusee clocks made to look older.
I kept each one open in a new tab as I searched through ebay. AT the end I noticed all 3 clocks are from the same seller.
The seller does not state any of them are old and on the RAF sector clock he does state ' Not a wartime original.' So I am not saying the seller is doing anything wrong, but providing the listings just so other people can see more examples of modern fusee clocks made to look older. Although the fact he has 3 fusee clocks all with the same movements in them and different dials and does not mention anything on the clock that has GWR on it that is not original but does on the RAF clock is a bit odd.
Note the are all hinged from the left, have solid pillars with no turning on them and wire instead of chain or cat gut and the finish on some parts are average. Not to mention to me all 3 of the dials just didn't look right.
https://www.ebay.co.uk/itm/Fusee-10-Inch-Dial-Clock/232804820013?hash=item36343fa42d:g:8ugAAOSwQQlbITNS
https://www.ebay.co.uk/itm/8-Inch-Dial-Fusee-RAF-Sector-Dial-Clock/332679578519?hash=item4d753f8397:g:pnMAAOSwnvVbGowW
https://www.ebay.co.uk/itm/Fusee-12-Inch-Dial-Clock/332632724560?hash=item4d72749450:g:F4UAAOSwFWda4cMa
On ‎18‎/‎06‎/‎2018 at 2:28 PM, Tmuir said:
But wait he has more.
I could be wrong but I think this LMS clock may not be original.
https://www.ebay.co.uk/itm/Fusee-12-Inch-Dial-Clock/232798691876?hash=item3633e22224:g:mA8AAOSwbbRbGoyg
:D
Now this is genuine lol, just look at the hand painted dial, must be all of 3 weeks old, my granddaughter could make a better job of that..
I just noticed another tell tail sign when I went back to look at the 'LMS' clock for a giggle. It has philips heads screws used in the clock case. If it was a genuine clock all screws would be fkat head screws not philips heads.
The pendulum rating nut is also wrong.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
    • Wie ging die Sache weiter?   please use English for your posts    Tom
