Hi Guys, I was gifted this watch a few months ago, and I have been searching ever since to try and find some history about it and which movement it has in it.
Could anyone shed some light on it and let me know ?
Thanks,
Chris.
Thank you, so I am assuming it's just a 1970's mass produce budget watch ?
It really has took my fancy as I don't own anything like it and it works very well, I don't think it has actually been worn very much as it's in excellent condition.
I can't find any reference to it on Web so I don't even know if it is the original strap but have no reason to think otherwise.
Will it be an original Duward as I can find reference to that and something similar but not sure ?
Obviously the day is in spanish, was it made for the Spanish market or south America ?
Thanks, Chris.
Duward are a spanish watch making company. I would say that is the original bracelet. Be careful if that bracelet breaks it might be hard to get another. There not top notch movements, but there good movements.
Think the correct name for this watch is Aquastar . Aquastar made them. And then each country rebranded them with there own name. Duward is a Spanish watch company. If you google Aquastar you will find such fine makes as Tissot and Heuer . Great looking watch.
Edited by rogart63
    • To add to this unusual cleaning idea, there is another type of device whereby the internal spinning parts that move through the fluid are not physically connected to the motor.  The internal whisk is propelled via a magnetic connection, so no damaged gaskets due to solvent contamination.
    • This is a method that Jon uses, and has posted a video of performing it somewhere .
    • Did you watch the whole video? Once Alex has set the stud, he first corrects the best error, then checks that the hairspring coils are breathing concentrically, then turns the stud to centre the hairspring between the open regulator pins.  He then checks that the regulator can traverse the terminal curve without disturbing the hairspring. A correction is needed, which he performs.  He then reinstalls the balance and re-centres the hairspring between the regulator pins, and verifies that the regulator traverses the terminal curve without disturbing the hairspring.  Finally, he demonstrates how to close the gap between pins.  He then recaps the whole process, fleshing out more detail. If you follow this process, you have correctly set up the regulator pins, and are ready to set the rate of the watch.  If you are interested in learning more about the effects of the regulator pin spacing on positional rates etc, you can read any literature regarding regulator pins. The etachron system makes adjusting beat, centering the hairspring between the regulator pins and adjusting the gap between the pins very convenient, but the same rules that apply to old style regulator pins apply to the etachron system.  This video explains the basics :    I hope that helps, Mark
    • Some photos of the angles you are talking about, and the changes you are seeing to coil spacing etc. would be really useful. Part of your problem could be that you are closing the pins too far and pinching the hairspring. Adjusting the pin separation should not affect amplitude. Nor should it change the coil separation.
    • Did you try it on a Rolex ref. 16600 specifically? Congrats on the nice condition of the movement in your watch. Even so, remember to check the rotor play or those marks around the main plate may start to build up.
