So I have a question about service and service intervals. What criteria do you use for service? Timekeeping -+ or determined schedule regardless?
Just curious and looking for a best practices approach ?
My take would be five to seven years between services with new synthetic oils. If you buy an old watch without history, then better to have it serviced as soon a s possible. I'm sure other will have different views.
Hi,
   A watchmaker years ago gave me his business card. I don't remember how long ago that was but you can tell how worn it is now. On the back he explains his theory of service intervals. Of course things have changed with the times but I just like the card. I took a picture with my smart phone but I think you should be able to read it.
Charles K
I love the card, thank you for posting Charles!
Now the question is settled and the formula found. No half years and round up (0.6 > 0.5 = 1 :
New formula: 5 years +7 years +2 years ┐- 4 =14/3  ┐- 4 = 4.666666666666667  ┐- 4 = 5 - 4 = 1 :woohoo-jumping-smiley-emoticon:
Look at the whole watch.
If the case is reasonable tight.. (waterproof is good). and used normally. then I'd say you're good for 5 years. This is for good quality newer watches like omega, seikos... you get the idea. Not only is dust getting in the case a problem.. if the watch is not reasonably tight the oils will dry out faster.
If the watch is not wterproof and / or sees rough use I would adjust the interval to around 2 years, talk to the owner to see how he plans to use the watch. Russian watches have a combination of poor cases and designed with a weaker mainspring than is usually found in a similar swiss watch.. hence need to be serviced more regularly.
Watches with hi-beat (36000bph) needs good fresh oil.
Chronos need servicing at 5yrs ... anything more is pushing it.
Dress watches with slim mvts have less powerful springs and fine pivots (less energy available) and need more frequent servicing. Dress watch cases are also pretty easily compromised! You will usually see them coming in regularly for service as they spend a lot of time in the drawer waiting for special occassions and the oil dries out.. result non-running watch.
then maybe learn
As Geo said, if you dont know the history... get it serviced.
HTH
Anil
Some watches have weak points.. the intermediate winding gear on the automatic module on some Zenith chronos is a good example. On a lesser note, seikos are generally fine but the rotor bearing inariably wears.
Rolexes will tolerate a lot of abuse due to the integrity of the case but you will sometimes come across models with a lot of wear as the robust movements keep on working ... worn rotor bearings is common on older rolexes.
OW! Anil, what about my beautiful formula!
Forget the formula, I go with what you just so well explained! It makes a lot of sense!
So my Benrus just had the winding stem fall out. Will not wear it tomorrow :D. Guess what watch is on the table for a strip and clean (FIRST). Then the hour hand disintegrated. But my question is what can I clean the dial with? It looks like tarnish or a grayish gummy substance? Posting photo. Any direction?
I don't think that watch dial is salvageable..I looks like the paint (silvered?) is flaking off and any further intervention will lead to more of it dissappearing.
Cleaning is one thing but how do you clean something that is missing?
Redial is an (expensive) option, does the watch have sentimental value?
Before commiting to a redial, I would service it.. no point having a nice dial but later discovering the movement has issues which costs more money! A lot of these older watches have cracked jewels... they still run but to get it done right means replacing the jewel/s and not many people do that anymore...(expensive!).
Also these dials look bad outside the case but once you get it back in the case it may not be so bad.. some of them had chunky cases and crystals so the bad dial may not be so obvious. Try to mildly polish the hands and use a toothpick with the point cut to a chisel shapr to clean up the hour markers on the dia, you may find that its not that bad after all!
Anil
Hi Gary, use a cotton bud dampened with a very dilurt solution of washing up liquid and very gently swab the dial. Finish swabbing with clean water to ensure that all traces of detergent is removed.
You could also try a cotton bud and iso-propyl alcohol, but try it on an edge first to make sure things are OK before doing the whole dial.
Do not use cellulose thinners, acetone or an ultrasonic cleaner, all will damage to the delicate finish.
    • Alex mentions the coils below the stud should remain the same as you move the regulator block along the terminal curve.  Mine do that. What he doesn’t discuss and is used in the other video is how the regulator block is used to adjust rate and positional error.  He also doesn’t mention how opening and closing the pins could and in my case does, alter amplitude  In Alex’s video once he sets the stud he never adjusts the regulator pins yet every new movement I get have the pins signing closed.
    • The video I linked above does mention the spacing of the hairspring coils, and the importance of the regulator being able to move through its full range without distorting the hairspring - the terminal curve of the hairspring must be concentric with the regulator pins throughout the regulator’s range.  If you meticulously follow every step in this video, the regulator system should behave as intended, regardless of the brand of the movement.  Best Regards, Mark
    • Hi friends! My mother got a bunch of old watches from a horologist who was retiring, and he subsequently passed away. It's been in her studio for years, and she showed it to me today and I just fell in love with it. Sadly, I don't know a darn thing about it yet. It's quite old, or at least seems to be. It has two winding arbors, but the key is missing. The crystal appears to be some kind of yellowed plastic, which is odd- I think it was replaced at some point to possibly protect it or something. If I had to guess, it's from the mid-19th century, given that it has no keyless works and that it says "Anchor Escapement" in French. It looks to be about 18 ligne, and the case fob is positioned in the upper right corner. The face is missing the dial, the hands, and a couple of the wheels that drive the hands- I think. But the movement itself seems to be in excellent shape. The serial number on the movement matches the number on the case- it's stamped on the movement and on the case in two places. I haven't started any disassembly yet, but I'm wondering if anyone can give me some idea of what kind of movement it is, and where I might look to see what parts are missing from the face. i may even have a dial that would fit it. It's in good enough shape that I think I could get it running, assuming I could find the missing parts. Any insights are vastly appreciated and thank you! Addendum: The inside of the case has some *very* tiny scratched numbers and letters in it, but I am having an extremely hard time seeing what they are. Like "N 99" and "No192X", They were clearly done with some kind of sharp stylus and maybe they mean when it was serviced or by who? Addendum the second: At least one of the scratches seems to say "N1921X" or maybe "W1921X". Serviced in 1921? And the inside lid of the case has the letters R H with a star between them, and a very tiny mark that says "ARGENT" in a u-shape.
    • I’ve watched every video I can find on YouTube. Some of the info is contradictory and none mention  the effect on amplitude or spring coil spacing which I observed. I was hoping someone here is a Seiko expert and knows these inside out.
    • This video explains how to set up and adjust the etachron regulator :   I hope that helps, Mark
