Longines Quartz
Hello all. I am new to this site and have to say I am very humbled by the amount of information discussed in this forum. I have learned a lot by reading some of the discussions. I love precision parts as I have been in the aero space business for over 30 years in the machining/manufacturing sector. Watches have always been of great interest to me but not until now I have decided opening them and looking at those marvelelous machined precssion pieces used to put movements together. I am passionate about it now.
Now on to my own topic. I need help opening this Quartz Longines watch. Can anyone tell me the way to get this movement out of the case? I have added 2 pictures to show the face and movement. Thank you in advance for your help.
Welcome to the forum Cesar.
Given that the shape of the dial, it will have to come out the front. The bezel and glass will first have to be removed, but not having worked on one, I am reluctant to suggest the next move. The bezel screws might be real and might be decorative. Given the quality of the watch, do not proceed until someone confirms what is required.
Geo, I tried to remove the screws but they seem to be decorative. I was thinking it comes through the front but was reluctant to try to force it. It does not suggest anywhere that you should use a 1200 wrench so I assume it is not under pressure. Thank you for your suggestion. I will wait to see if anyone has worked on one before.
Hi a am also new to the forum  but I do have a suggestion.   From looking at the movement there appears to be movement hold-down screws at 11 and 4  if you carefully remove those after removing the watch stem as described above the movement should come out of the back  one thing to note those screws may have to just be turned slightly to orient the underside of the screw.  I would need to have a closer look to be sure   actually you may be able to rotate the movement to see the underside of the screw and put it in the proper orientation.  best of luck.
Sincerely
Jim
Jim, I had those screws removed but the movement only rotates. It seems like there is a spacer holding the movement but I haven't found a way to remove it as well. If you notice closely, the dial is slightly larger than the movement. Which makes think I would have to remove the spacer or the Crystal. I will take a look at removing the screws to see if I haven't miss anything. Thanks for the response and suggestion.
Additionally if you look closer there is a small area at 12 where you can view the orientation of those screws I think.  This is just a guess but if you loosen up 1/2-3/4 turn  on those screws the movement should rotate easily   The screws may not come out but just need orientation first.   Just go slow and be careful and gentle
Again best of luck
Sincerely
Jim
Is the spacer in the back rusted in place or jammed ?  or is it actually part of the case?  I have worked on many front loaders  I defiantly would have gone after the back looking at that movement. Especially  if the front screws just turn.   Let me know what you find   I am sure there is some special Longines trick involved.    One other thought  sometimes there is one orientation that will allow the movement to release.
Jim, it is hard to tell if it is part of the case or not. It doesn't look rusted just dirty as you can see in the picture. I will try rotating it to see if there is in fact a position where it will come off.
Geo, I will do measurements to figure out the size.
I second Jim in the suggestion about the screws. It seems to me that once loosened, the movement should rotate in such a way that the screw at 11 will be positioned at the gap at 12. Then it is a matter of lifting the movement. Of course, it is not confirmed so proceed with caution. Taking measurements is definitely good!
Well after trying all the above I am still not able to remove t movement. The dial us bigger than the back opening and I cannot rotate the movement because of the dial's shape. Back to the drawing board. Any other suggestions will be appreciated.
Post high resolution close ups of the edge of the watch taken at the 12, 3, 6 and 9 to let us see more detail of the bezel. It just might be more obvious to some of us how to remove the bezel if seen from these positions.
My opinion, for what it's worth - and I don't have half the skills of some of the guys here - is just a bit of logic. The movement has to be attached to the dial - the dial is larger than the hole in the rear casing - ergo: it must be a front loader.
Looking closely at the face of the watch, those screws appear to me to be more than just moulded into the bezel as a decorative item. Note the slight off-centredness of the screw next to the date window. Have you tried them all carefully? Do they unscrew but have no effect on the tightness of the bezel? If both of those things are true, or they don't unscrew at all, then the bezel must snap off.
So. as Geo rightly says, look carefully at the bezel edge, where it joins the case, and see if there's anything remotely like a prisable join. And post some pics!
Cheers,
Will
Edited by WillFly
Okay one last thought from me  :-)     Many years ago I worked on  a PP that had a 18k split case in order to remove the movement the middle of the case had to be split.  Fortunately I knew an older watch maker that showed me how to split it using a double sided razor blade.  Still makes me nervous.   If the side of the watch looks like it has a seam it could possibly be the same arrangement.  look on the side of the case for a faint line.   If you can post a pic of the case side we can all chime in  :-)     again good luck
Sincerely,
Jim
Jim,
i am trying to post more pics from different angles including the side but being new to this site I need help doing that. Please let me know how to do it.
It looks like the Basel can be removed but again I am reluctant to insert anything on it. I have a Longines watch with a split case and that one is easy to take apart. This one has been a challenge.
Thanks for all the advice.
Cesar
Re the 2 screws on the back...
If the movement is loaded thru the back these srews will do nothing to hold it in.
I think the bezel comes off once the screws are undone, some may be decorative... 12 seem a bit excessive!
Anil
I am going on vacation but will be back. I will try to remove the Bazel and post the results. Have a great couple of weeks. I will be reading posts if anyone comes up with other suggestions. Thank you all.
Dear Cesar,
I am also new to this site   but I am sure one of the senior members will chime in and assist you in uploading.  We are all interested in the outcome now :-)
Sincerely
Jim
    • Posting a photo of the keyless works may at least give some guide to the manufacturer.
    • poising and the right discussion group with the right people it can become an extremely heated conversation like so many other things in watch repair. but it really shouldn't be an issue as long as everybody understands what they're supposed to be doing and why? the first and most interesting problem we have is what exactly is the poise balance wheel? Now understand the question we need to clarify and to clarify we need timing specifications that typically do not exist for vintage watches. so the overly simplistic of all of this is you only have a poise problem if the positional timing is outside of the specifications of the particular watch your working on. now the quote above isn't quite right the reference to a new balance wheel if you purchase a new balance wheel it's supposed to be poised from the factory. but it's only going to be poised to whatever the factory specifications are if you're expecting your whatever to be a chronometer then it's not going to be poised to your specifications. Then on any modern balance wheel without screws you shouldn't have to poise at all? For instance here's an interesting link on poising. What makes it interesting is that the balance wheel he showing is a modern balance wheel that really does not need any adjusting at all as it would be within the specifications of the factory but he is still going to show you how to do it anyway. https://great-british-watch.co.uk/how-to-poise-a-balance-wheel/ so is poising necessary sometimes. How do we know poising as necessary? Easy put it on the timing machine look at the watch in four positions is the timing outside of whatever you perceive the specifications are supposed to be for your watch?  I was looking at some of the watches that I do have timing specifications and so far the greatest I've seen is one minute of out of poise would be considered acceptable at a fully wound up watch. so positional errors get all kinds of differing numbers depending upon the specifications.
    • So this was something I bought a few years ago. I've always been interested in how hairsprings work, and pretty good at the manipulation of them from day one, mostly because I have rock steady hands and very good dexterity. Watching guys hands on the UTube flutter around when working on hairsprings....🤔 makes me wonder whats going on ? I may be just very lucky in that respect. This isn't the better, more expensive Luthy, but it works lovely. I have only used it once to check a hairspring's frequency, something unnecessary, as a timing machine can do just that, but it was accurate compared against. I guess these things were a timesaver, after pinning a new hairspring to a collet, something I might never do, but probably will 😄
    • Hello community, I have posted about this a month ago but wasnt sure if I replied to the previous post it would show everyone.    I havent been able to identify this exact movement therefore I havent been able to figure out which click spring and how it actually sits on this movement. I bought a set of 100 pcs on Cousins but i cannot figure out what shape it has to have or where.      It doesnt have a little whole lite other movements, its not a long shaped one that sits under the ratchet wheel.  Here are a few phtoos. Thats all i need to be able to finish this one, once I figure it out I will re clean and re oil it since its been there for a month with me trying to finalize it here and there .   Thank you for your help.     I have tried one that is bent on one side /lateral and other side is either up or down but however I put it , it doesnt spring the click back
    • I would concentrate on a single piece of material at the correct thickness. I have a few rolls of narrow thin steel that I sometimes use for making setting levers. Very cheap to buy and will last all of my life, 0.3mm is the thinnest I have. But there are other common place items you can use, stanley knife blades I think are around 0.4mm, single edge razor blade scapers 0.2mm and beard razors finish at exactly 0.1mm, pretty close to what you require.  Feeler gauges are also a good option. Fiddling around with multiple layers of foil doesn't sound like fun, and aluminium will compress easily,  if not when fitting , then later down the line. Ive found watch paper under a bridge before, probably less likely to compress than tin foil. Sounds wrong putting paper in a watch, but trapped between the plate and a bridge, I cant see a big problem. Besides it will soak up the extra oil from over-oiling 😄
