Hi,
please move to correct topic section if not correct.
I really enjoyed watching this video
it made me want to do it too.
I’d like to build a rolex ref 6200 hommage but i am a noob, so I write to hear from who’s more expert than me.
I’d like to purchase parts online, but which automatic movement could be a good choise?
I was thinking 2824-2 eta, on ebay, but what is a good price and how i recognize a good one? And if is a clone how do i recognize a good copy from a bad one?
if not this eta which one could be a good reliable automatic movement but still affordable?
Hi there, to really find answers quickly to your questions i would pop over to homage forum for loads of builds,,and i mean loads and shedloads of information on movements etc, also on the movement front you could also pop over to rwg.bz its a rep watch site but they are a  friendly bunch and there are posts on spotting  the differences between a gen eta and Chinese.
Or there is probably someone here that could answer everything of the top of their head for you.
No my friend it is a totally different site/forum, again very helpful bunch with a wealth of knowledge on the subject of self builds, there is even a submariner/oyester sub forum on there.
Order made,
i switched from eta to a miyota 8215, it seemed like a good piece, maybe less fancy but still something that gets the work done, pieces will arrive at the end of july/mid august, wait and see!
    • This eBay listing seems to verify that the watch disassembles as I suggested : here. The display caseback is held by the section that pushes out of the outermost rear bezel.  The movement seems to be a Ronda 1113. Best Regards, Mark
    • Decided to update with the repaired watch back in rotation and the new anniversary gift.
    • I’ve been playing with a NH35 movement that which has the classic Etachron regulation system and a few balance assemblies as practice. What I’m trying to do is get comfortable with the effect both the stud and regulator pin positions have on rate and positional error. When I install a new balance assembly I install it with the assembly in place  on the cock and cock is attached to base plate. I use the back of the tweezers to push the stud into place and feel the click. However, I noticed that the angle of the stud can be adjusted and what I also noticed is that some movements have the stud carrier arm bent down a little and that changes the angle of the hairspring leaving the stud. This angle effects how the spring goes through the regulator pins and also the spacing of the coils opposite the stud. What I thought I was supposed to do is set the regulator block in the middle of the curve, open the pins, and use the stud angle to center the spring.  Then the stud is set.  Now on all the new NH movements I have seen the angle of the regulator block is about 60 degrees counter clockwise from full open. I watched a video where the author used the regulator pin adjust to adjust rate and position error. When I close down the pins I do notice that the rate increases but also the amplitude drops, the coil spacing changes and hairspring appears slight straighter between the stud and the regulator block. If I open the pins the amplitude comes back, the spring breathes a bit more between the stud and the regulator block and the rate slows.  So, a long post I know but I would really appreciate any advice on how to correctly adjust the etachron system for rate, amplitude and positional error.
    • Aw come on Andy, it was just a comparison between spending 30 quid and tackling a tricky piece of work. You appeared to be volunteering,  i volunteer for stuff all the time it gets me into all kinds of trouble.
    • It's not really shown here , but the blade flips over, so it faces the other way. The knob and threaded case holder then pushes the caseback seam into the blade. Once the blade starts to penetrate into it, the lever and blade are lifted , which should hopefully pop the back off. A lot of fashion style cases have very tight seams and need a sharp blade to start separating them.  Don't buy the cheaper plastic versions of this tool, the posts with the pins through for blade holder break easily if the apply extra force to blade.
