Hello. I am working on a vintage Bulova from 60s.
I am trying to take apart the movement from the case but case is in somewhat strange structure.
As I tried to remove the caseback, I instead took apart the upper part. Then I removed the crystal and the dial to find the movement.
Here is a problem. I cannot find a way to remove the stem from the movement from the dial side.
Please help.KakaoTalk_20180623_223034669.jpg.fa096b52f86b234fef7e18689b693c98.jpg
Must a split stem . You should be able to see it if you look down the crown tube . There is no other way to get that stem out or even in if there isn't a split stem on that.
Your advice was of great help. I pulled out the crown and the stem split in two.
Now I can look at the whole movement. Thank you for helping me out.
