Kilkmaru Posted June 27, 2018 Posted June 27, 2018 The crown won't come out with just using my fingers to pull on it.. I don't want to break it as it seems to be a wind up which iv always wanted. Quote
frenchie Posted June 27, 2018 Posted June 27, 2018 Welcome! Give the amount of rust, I'd be surprised if the crown actually came out... Can you post a picture of the dial side of the watch? Quote
noirrac1j Posted June 27, 2018 Posted June 27, 2018 Looks like a considerable amount of water damage, and stem/crown is fused with rust onto the case. If the dial side shows signs of rust, that means its a nightmare underneath and its not worth the trouble--unless there is some personal value for you. J Quote
clockboy Posted June 27, 2018 Posted June 27, 2018 I think it is a Timex. Water damage is extensive therefore a challenge for sure. Quote
Kilkmaru Posted June 27, 2018 Author Posted June 27, 2018 6 hours ago, Kilkmaru said: The only rust I see is right near the entrance of the crown buti am going to look deeper in a few.... Quote
frenchie Posted June 28, 2018 Posted June 28, 2018 Timex with a movement that's riveted together... good luck with that one... Quote
JerseyMo Posted June 29, 2018 Posted June 29, 2018 1973 Timex Mercury with a #27 movement. I've restored worse than that. Quote
JerseyMo Posted June 29, 2018 Posted June 29, 2018 10 hours ago, frenchie said: Timex with a movement that's riveted together... good luck with that one... absolutely not riveted together. Quote
jdm Posted June 29, 2018 Posted June 29, 2018 2 hours ago, JerseyMo said: 1973 Timex Mercury with a #27 movement. I've restored worse than that. A kind reminder: Quote
frenchie Posted June 29, 2018 Posted June 29, 2018 7 hours ago, JerseyMo said: absolutely not riveted together. My bad, I didn't see any screws. Quote
JerseyMo Posted June 29, 2018 Posted June 29, 2018 this is a factory made test piece from the estate of a former Timex engineer that worked in the QA department. Quote
