Hello All,
I have been buying some bits and pieces to get me going and have come across this: Anchor branded crystal lift tool.  I know its not the same quality as Burgeon but will it do the job.  As you are aware I am totally new to this and would appreciate any advice.
Regards
Col
Hi colored,
I have come across some anchor products and the quality in mostly shaky at best. I believe you might hopefully make this product work most of the time. I personally use the Bergeon one which in most cases is trouble free...but more expensive.
And welcome aboard!
Hi Geo, I wonder if there is anything you can't get to work! :)
By the way, good to know those work! Thanks.
Edited by bobm12
Yes, my 955i Triumph Daytona, no fuel getting to the injectors. I've not given up yet though.
Triumph! good man. Had a Speed Four a few years ago, now have an 2003 Trophy 1200. I did have a couple of injectors go south on the Speed Four, I wouldn't expect all 3 to go but you never know, If not its probably the pump, possibly wiring. Again the Speed Four had an intermittent problem with the engine cut out, eventually traced to a bad factory join in the middle of the main loom.
That could be easily fixed with the anchor crystal tool I think! :) Just use it to extract the loom! (As if I knew what you guys are talking about....woooosh, over my head!) :)
All very similar though, I initially took up watchfixing (I fix them, I don't make them) as a substitute for fixing motorbikes, all very similar just an awful lot smaller. Plus the added bonus of a nice warm room in the winter instead of a very cold garage.
I agree totaly Blacklab, it seems like a good choice for winter time! I'll get a warm room anytime for a workshop! I've never been good at motorbikes although I used to dabble more with cars...that was soooo long ago it seems like another life! But I loved it therefore watches.
@Geo: I bet it won't be long now you'll be riding that bike again! keep us posted!
Nice bike Geo.  I had the 955i RS sprint with the same engine and loved it.  However I had to get rid before it got rid of me. A pal had the speed triple with the same fault i.e. no fuel and it turned out to be a wiring loom fault.  I am looking for something a bit more docile now, age is getting the better of me.
Thanks for your advice re crystal lift
Col
1) I am looking for something a bit more docile now, age is getting the better of me.
2) Thanks for your advice re crystal lift
Col
1 - I refuse to grow up.
2 - It's all the lift that you'll need.
A few days ago I took apart a door handle that was squeaking. Watchfixing skills came in handy... :)
So instead of squeaking it now goes tick tock.........a far better sound!
    • This is a method that Jon uses, and has posted a video of performing it somewhere .
    • Did you watch the whole video? Once Alex has set the stud, he first corrects the best error, then checks that the hairspring coils are breathing concentrically, then turns the stud to centre the hairspring between the open regulator pins.  He then checks that the regulator can traverse the terminal curve without disturbing the hairspring. A correction is needed, which he performs.  He then reinstalls the balance and re-centres the hairspring between the regulator pins, and verifies that the regulator traverses the terminal curve without disturbing the hairspring.  Finally, he demonstrates how to close the gap between pins.  He then recaps the whole process, fleshing out more detail. If you follow this process, you have correctly set up the regulator pins, and are ready to set the rate of the watch.  If you are interested in learning more about the effects of the regulator pin spacing on positional rates etc, you can read any literature regarding regulator pins. The etachron system makes adjusting beat, centering the hairspring between the regulator pins and adjusting the gap between the pins very convenient, but the same rules that apply to old style regulator pins apply to the etachron system.  This video explains the basics :    I hope that helps, Mark
    • Some photos of the angles you are talking about, and the changes you are seeing to coil spacing etc. would be really useful. Part of your problem could be that you are closing the pins too far and pinching the hairspring. Adjusting the pin separation should not affect amplitude. Nor should it change the coil separation.
    • Did you try it on a Rolex ref. 16600 specifically? Congrats on the nice condition of the movement in your watch. Even so, remember to check the rotor play or those marks around the main plate may start to build up.
    • Here is a method described in the watch repair book of Mark W. Wiles. Don‘t hammer, just tap very gently! Another option:
