I have a question for you guys,
Given that vintage watches are kind of more sensitive to impact than incabloc et al protected "modern" ones, Is there a way to remove the original jewels on the balance wheel and substitute it for an incabloc sort of setting?
I'm thinking about those beautiful Hamiltons, etc....
Simple answer; yes...............
But,
Full answer; there is no reason why you  shouldn't  push out the original jewels and replace with incabloc settings. This will almost certainly require the plate and cock to be machined to receive the incabloc settings which may be possible with your staking set if you have reamers that fit, otherwise a lathe would do the trick.
However, you will not be able to use the original balance once you've switched out the jewels. The pivots for Incabloc settings are a different shape to the non shock settings so you will need to source an appropriate balance, or balance staff (and then obviously change that for the original and re-poise), or if there isn't one available, make an appropriate new staff.
So yes it can be done but there's a lot more to it than just pushing out the old and pushing in the new.
I agree with Marc.
It wouldn't be quite as difficult as fitting a co-axial escapement to an Omega Speedmaster, like George Daniels did with his prototype.
I see, then it would be out of the question to go to all that trouble unless there is a really good reason to do it...or maybe as a learning experience when I'm at the right level to try it.
By the way, is there a link for this Daniels job?
Thanks!
Here's a quote for you Bob
"To try and rectify the situation, he suggests they attempt to put the escapement into a wristwatch. The chief liked the idea and produced a 2.5 mm thick movement for the escapement to be fitted to. Daniels had previously, on his own whim, put the co-axial into an Omega Speedmaster, but was not sure he could do so to such a thin watch. He was sure the chief held the same opinion and "I [Daniels] realised that I had been outwitted." If he couldn't fit it to a modern watch than there was no point in progressing this work. He went back to London to solve the problem."
And here's a link to something that will intrigue you:-
http://chronomaddox.com/daniels_co-ax.html
What an ordeal Geo, and a very interesting story. I'll keep following the links on the page to read more. Thank you for the interesting reading!
    • Alex mentions the coils below the stud should remain the same as you move the regulator block along the terminal curve.  Mine do that. What he doesn’t discuss and is used in the other video is how the regulator block is used to adjust rate and positional error.  He also doesn’t mention how opening and closing the pins could and in my case does, alter amplitude  In Alex’s video once he sets the stud he never adjusts the regulator pins yet every new movement I get have the pins signing closed.
    • The video I linked above does mention the spacing of the hairspring coils, and the importance of the regulator being able to move through its full range without distorting the hairspring - the terminal curve of the hairspring must be concentric with the regulator pins throughout the regulator’s range.  If you meticulously follow every step in this video, the regulator system should behave as intended, regardless of the brand of the movement.  Best Regards, Mark
    • Hi friends! My mother got a bunch of old watches from a horologist who was retiring, and he subsequently passed away. It's been in her studio for years, and she showed it to me today and I just fell in love with it. Sadly, I don't know a darn thing about it yet. It's quite old, or at least seems to be. It has two winding arbors, but the key is missing. The crystal appears to be some kind of yellowed plastic, which is odd- I think it was replaced at some point to possibly protect it or something. If I had to guess, it's from the mid-19th century, given that it has no keyless works and that it says "Anchor Escapement" in French. It looks to be about 18 ligne, and the case fob is positioned in the upper right corner. The face is missing the dial, the hands, and a couple of the wheels that drive the hands- I think. But the movement itself seems to be in excellent shape. The serial number on the movement matches the number on the case- it's stamped on the movement and on the case in two places. I haven't started any disassembly yet, but I'm wondering if anyone can give me some idea of what kind of movement it is, and where I might look to see what parts are missing from the face. i may even have a dial that would fit it. It's in good enough shape that I think I could get it running, assuming I could find the missing parts. Any insights are vastly appreciated and thank you! Addendum: The inside of the case has some *very* tiny scratched numbers and letters in it, but I am having an extremely hard time seeing what they are. Like "N 99" and "No192X", They were clearly done with some kind of sharp stylus and maybe they mean when it was serviced or by who? Addendum the second: At least one of the scratches seems to say "N1921X" or maybe "W1921X". Serviced in 1921? And the inside lid of the case has the letters R H with a star between them, and a very tiny mark that says "ARGENT" in a u-shape.
    • I’ve watched every video I can find on YouTube. Some of the info is contradictory and none mention  the effect on amplitude or spring coil spacing which I observed. I was hoping someone here is a Seiko expert and knows these inside out.
    • This video explains how to set up and adjust the etachron regulator :   I hope that helps, Mark
