It’s driving me nuts.
Which end goes into the baseplate the long point or the short point?
I can’t get it to stay put.
The pivots don’t appear to be broken.
Thanks for any help you can provide.
As OldHippy points out, if you can imagine that the escape wheel is pictured in place below, it's rotation would be in a clockwise direction.  You see that the left hand pallet stone is "open" at it's face angle to allow the next tooth to come in and the right pallet stone face is at an angle to so to speak "catch" the face of the escape wheel tooth.
I have an image from Jules Borel showing the escape wheel in position.  I hope this simple thought process makes it stick in your mind better.
Quote
Edited by GeorgeC
I have the pallet in position and the pallet cock screwed down.
I am able to move the pallet fork back and forth.
I turned the ratchet wheel to put a little wind on so that I could insert the balance wheel. This where I’m having the problem now. The balance wheel won’t catch.
On ‎03‎/‎07‎/‎2018 at 8:32 AM, oldhippy said:
They fit this way.
I know nothing about escapements, Is this the same way round as for fitting to a clock escapement..Thx Len
If the clock has a platform escapement, it is the same way.
It will take a bit of practise at first. Some balance complete are more difficult to fit then others. You just might have a stubborn one. Just be careful.
10 hours ago, mlfloyd1 said:
I've put it in and out so many times without success that I hope I haven’t damaged the hair spring.
If the pin doesn't go in right away lift the balance slightly and rotate in the direction where the pin stopped by the pallet arm, so it can fall in place.
I think the balance spring is distorted after so many fruitless attempts.
Now I have to order a new spring, balance wheel, and cock.
I won’t even try to put it on cock; I have to buy it completely assembled.
Oh dear...thats not good.
A bit of advice.. whenever you get stuck, stop and think about it.
In the first instance you had a problem figuring out which way the pallet fork went in. Your next step should be to observe how the pallet fork interacts with the other parts.. in this case the escape wheel and balance-wheel. The escape wheel end will not help you but if you had looked on the underside of the balance you would have notice the roller jewel and you would then realize that there's only one way the pallet-fork will go as there is a centre-pin on the pallet-fork (called the guard pin) which would interfere with the roller jewel if the pallet fork is installed upside down.
In the second instance, you would realize by now that the roller jewel is the one giving motion to the pallet fork, as such it needs to be in the middle of the pallet fork arms. If it does not swing freely you need to eliminate probably reasons it doesn't ..is the balance in the pivots? Is the roller jewel in the fork?
It is important to always analyze why something does not go well,  you WILL get better at this but you need to consciously do this in the beginning. It will become second nature after a while.
I hope the above doesn't too much like a lecture but if you don't develop the habit of thinking through problems you will end up being more frustrated and the end result is a mangled hair-spring.
As always...good luck!
Anilv
I have had the same trouble until I found (by myself) the method that I gave you before. It was also quite difficult for me to position both the pallet and the balance pivots in the jewels.
Now, if your goal is to get the watch running I recommend that you buy a new movement complete.
But if instead is to learn I recommend that you follow Mark's lessons from the start, possibly practicing on 6497 movement, or other large one of low value.
One can fully understand the theory and the practical problem but still have trouble executing the task due to the lack of manual dexterity and proper tecniques. You hear that these are developed over time but in reality like every skill in life there is also a talent factor, plus good sight and hand steadiness required. If these are not there to a certain amount it's going to be a tough battle with lots of losses.
I didn’t buy another 7S26 movement; instead I purchased a new balance/cock assembly.
This time it went in on the first try.
The movement runs great.
I have two spare 7S26 movements now since I upgraded my SKX007 and 009 to the NH36 movement.
Thanks for your help.
  • 2 years later...
Absolutely splendid advice, and if I may I would suggest taking a lot of pictures (more pictures than you think you might need). It has helped me a lot.
Not one bit! This is what WRT is for!
I don't believe in that idea one bit. I always tell my students (IT) and my kids that the only "talent" you need in life is the will and the ability to put in the hours. In general, everyone can succeed if they put their mind to it.
Unless you have a physical disability, there are glasses, eye loupes, and stereo microscopes, and hand steadiness can be acquired by practicing breathing and relaxing (Tip: training competitive shooting is a great way to improve this).
    • To add to this unusual cleaning idea, there is another type of device whereby the internal spinning parts that move through the fluid are not physically connected to the motor.  The internal whisk is propelled via a magnetic connection, so no damaged gaskets due to solvent contamination.
    • This is a method that Jon uses, and has posted a video of performing it somewhere .
    • Did you watch the whole video? Once Alex has set the stud, he first corrects the best error, then checks that the hairspring coils are breathing concentrically, then turns the stud to centre the hairspring between the open regulator pins.  He then checks that the regulator can traverse the terminal curve without disturbing the hairspring. A correction is needed, which he performs.  He then reinstalls the balance and re-centres the hairspring between the regulator pins, and verifies that the regulator traverses the terminal curve without disturbing the hairspring.  Finally, he demonstrates how to close the gap between pins.  He then recaps the whole process, fleshing out more detail. If you follow this process, you have correctly set up the regulator pins, and are ready to set the rate of the watch.  If you are interested in learning more about the effects of the regulator pin spacing on positional rates etc, you can read any literature regarding regulator pins. The etachron system makes adjusting beat, centering the hairspring between the regulator pins and adjusting the gap between the pins very convenient, but the same rules that apply to old style regulator pins apply to the etachron system.  This video explains the basics :    I hope that helps, Mark
    • Some photos of the angles you are talking about, and the changes you are seeing to coil spacing etc. would be really useful. Part of your problem could be that you are closing the pins too far and pinching the hairspring. Adjusting the pin separation should not affect amplitude. Nor should it change the coil separation.
    • Did you try it on a Rolex ref. 16600 specifically? Congrats on the nice condition of the movement in your watch. Even so, remember to check the rotor play or those marks around the main plate may start to build up.
