If the winder is too tight it's most probably due to an old o-ring in the crown. It could also be done to old grease in the parts that wind the barrel.
Having said that, compared to ordinary time-only watches chronographs are more fussy about being serviced and I would say that it would be prudent to get it serviced and you'll be good for the next 5 years (more if used occasionally and stored in a dust free environment). These watches are quite desirable and should you wish to move it on a record of recent servicing will only add to the value!
Price of servicing depends on where you are.  Here in Malaysia you would probably pay around USD100-150 just for labour, parts extra.
Anilv
Sometimes dirt gets packed inside the button. By removing the stem and button it can be cleaned out. While the stem is out you could give it a little oil, re-fit and see how it goes.
This LeJour is very nice and certainly worthwhile to keep it running as it should. Try the suggestions already given for the tight winder, but I suspect you'll probably need a service overhaul because who knows how long its been since its been cleaned. As the mechanical complication on a watch increases, so too does the service cost--A chronograph is at the top. Overhaul in NYC is between $350-$450.
J
Thanks Everyone for the suggestions. Given the # of old watches I have and need of service. I am actually thinking of learning to service the watch. I will search this forum on how to get started and how long it will take to learn. It’s just not affordable for me to keep them and get them service.
    • Alex mentions the coils below the stud should remain the same as you move the regulator block along the terminal curve.  Mine do that. What he doesn’t discuss and is used in the other video is how the regulator block is used to adjust rate and positional error.  In Alex’s video once he sets the stud he never adjusts the regulator pins yet every new movement I get have the pins signing closed.
    • The video I linked above does mention the spacing of the hairspring coils, and the importance of the regulator being able to move through its full range without distorting the hairspring - the terminal curve of the hairspring must be concentric with the regulator pins throughout the regulator’s range.  If you meticulously follow every step in this video, the regulator system should behave as intended, regardless of the brand of the movement.  Best Regards, Mark
    • Hi friends! My mother got a bunch of old watches from a horologist who was retiring, and he subsequently passed away. It's been in her studio for years, and she showed it to me today and I just fell in love with it. Sadly, I don't know a darn thing about it yet. It's quite old, or at least seems to be. It has two winding arbors, but the key is missing. The crystal appears to be some kind of yellowed plastic, which is odd- I think it was replaced at some point to possibly protect it or something. If I had to guess, it's from the mid-19th century, given that it has no keyless works and that it says "Anchor Escapement" in French. It looks to be about 18 ligne, and the case fob is positioned in the upper right corner. The face is missing the dial, the hands, and a couple of the wheels that drive the hands- I think. But the movement itself seems to be in excellent shape. The serial number on the movement matches the number on the case- it's stamped on the movement and on the case in two places. I haven't started any disassembly yet, but I'm wondering if anyone can give me some idea of what kind of movement it is, and where I might look to see what parts are missing from the face. i may even have a dial that would fit it. It's in good enough shape that I think I could get it running, assuming I could find the missing parts. Any insights are vastly appreciated and thank you!
    • I’ve watched every video I can find on YouTube. Some of the info is contradictory and none mention  the effect on amplitude or spring coil spacing which I observed. I was hoping someone here is a Seiko expert and knows these inside out.
    • This video explains how to set up and adjust the etachron regulator :   I hope that helps, Mark
