Hello All.
I am completely new to watch repair.
I have watched Mark's videos and I feel confident stripping a movement down, BUT, I know I would fail to be able to reassemble in the correct order, Is there an industry standard way to organise parts for reassembling ?
David Miles ( UK )
Get yourself trays to organise the parts. Keep the screws together with their bridges.
Take many photos as you strip down to reference when putting back together and get yourself a good set of screwdrivers and tweezers.
Read up on how to sharpen your screwdrivers to fit the movement you are working on.
Buy some cheap old Swiss watches to practice on, start with manual wind watches.
You will almost certainly damage the first few watches you practice on thats why you need to start on cheap watches.
Also get yourself a few good books to read, Donald De Carles books are good, but if you want a modern one I recommend Maintaining and Repairing Mechanical Watches by Mark W. Wiles.
5 hours ago, DJMiles said:
Hello All.
David Miles ( UK )
David, An introduction first would be much appreciated before asking questions.
Us beginners must take extreme measures.  I photograph every step.  I've a camera with a macro lens set up on a table top tripod with an infra remote.  I just keep sliding the movement or parts on a cushion under the camera and snap away.  Its saved ,me several times.  Of course once a bit of experience comes, you start to understand whats what and where it goes, but I'm on the early part of the curve so photograph like crazy
I always take photos when I take a pocket watch apart, If it's a movement type I don't have photos of already. You would be surprised how often  I look back at them   :)
    • Alex mentions the coils below the stud should remain the same as you move the regulator block along the terminal curve.  Mine do that. What he doesn’t discuss and is used in the other video is how the regulator block is used to adjust rate and positional error.  He also doesn’t mention how opening and closing the pins could and in my case does, alter amplitude  In Alex’s video once he sets the stud he never adjusts the regulator pins yet every new movement I get have the pins signing closed.
    • The video I linked above does mention the spacing of the hairspring coils, and the importance of the regulator being able to move through its full range without distorting the hairspring - the terminal curve of the hairspring must be concentric with the regulator pins throughout the regulator’s range.  If you meticulously follow every step in this video, the regulator system should behave as intended, regardless of the brand of the movement.  Best Regards, Mark
    • Hi friends! My mother got a bunch of old watches from a horologist who was retiring, and he subsequently passed away. It's been in her studio for years, and she showed it to me today and I just fell in love with it. Sadly, I don't know a darn thing about it yet. It's quite old, or at least seems to be. It has two winding arbors, but the key is missing. The crystal appears to be some kind of yellowed plastic, which is odd- I think it was replaced at some point to possibly protect it or something. If I had to guess, it's from the mid-19th century, given that it has no keyless works and that it says "Anchor Escapement" in French. It looks to be about 18 ligne, and the case fob is positioned in the upper right corner. The face is missing the dial, the hands, and a couple of the wheels that drive the hands- I think. But the movement itself seems to be in excellent shape. The serial number on the movement matches the number on the case- it's stamped on the movement and on the case in two places. I haven't started any disassembly yet, but I'm wondering if anyone can give me some idea of what kind of movement it is, and where I might look to see what parts are missing from the face. i may even have a dial that would fit it. It's in good enough shape that I think I could get it running, assuming I could find the missing parts. Any insights are vastly appreciated and thank you! Addendum: The inside of the case has some *very* tiny scratched numbers and letters in it, but I am having an extremely hard time seeing what they are. Like "N 99" and "No192X", They were clearly done with some kind of sharp stylus and maybe they mean when it was serviced or by who? Addendum the second: At least one of the scratches seems to say "N1921X" or maybe "W1921X". Serviced in 1921? And the inside lid of the case has the letters R H with a star between them, and a very tiny mark that says "ARGENT" in a u-shape.
    • I’ve watched every video I can find on YouTube. Some of the info is contradictory and none mention  the effect on amplitude or spring coil spacing which I observed. I was hoping someone here is a Seiko expert and knows these inside out.
    • This video explains how to set up and adjust the etachron regulator :   I hope that helps, Mark
