  • 8 months later...
What is so keen about Vostok watches, is that they are inexpensive, have rugged simple ( and per some accurate)  movements, and highly moddable. You can change straps, bezels, probably hands too. Basically you can customize the watch to fit your personality. Small wonder they have a cult following. You may call  it a gateway fiending into horology and watch collection. And these watches due to low prices can be addicting. And that is not a bad thing.
Edited by cfc313
left words out
  • 2 months later...
To the original poster, sorry to bug, but do you still have the watch from the opening post? I've actually just started hunting for that exact configuration. I've seen a number of variants with different bezels, dial markings, and hands, but yours is precisely what I was hoping to track down.
Yep, I still have it! 😃
Hi VWatchie,
Interesting thread you started and thank you for walkthroughs on Russian watches, it helps a lot to newbies like me.
I just got the one below as a gift from a friend. Bought a donor movement from eBay to replace a couple of wheels that were somehow destroyed. I clean it, polish a little bit the crystal, restored the hour and minute hands and put a new second hand. Now, it´s my everyday watch and running strong.
Interesting posts about the Russian oils, it would be interesting to know if someone use it and observe a change in the performance. So far, I used those oils as recommended by Mark.
Anyone knows where to get crystal and gaskets for Komandirskie?
On 1/21/2022 at 5:53 PM, Kepas said:
Definitely I´ll get some parts from them..... very inexpensive too!!!!!
That's what's so great (among many other things) about these watches. Rugged and reliable as h-ll, Swiss heritage (if you understand these movements you'll understand Swiss movements as well) and parts can be sourced for next to nothing.
Thanks for your contribution @Kepas!
11 hours ago, VWatchie said:
Good advice, and you can find these parts on eBay as well which can be a bit faster depending on where you live in the world. Just search eBay for "komandirskie crystal" and "komadirskie gaskets".
Thanks for the advice VWatchie, as Meranom doesn´t ship where I live.... Actually, I was able to find a vendor with a myriad of plexiglass for Russian watches. That encourage me to restores some models I got with non-round glasses.
Yeap, totally agree with you. I started with some old 2602 Pobeda and then move to Raketa 2609, Wostok 2214, 24xx, putting together some movements from steampunk lots. They cost almost nothing and work amazingly well after decades.
Thanks for your contribution to the forum, I always learn something from your posts.
  • Similar Content
    • Update: The demagnetization only helped temporarily, maybe it pulled the wheels into a position where they liked each other. I have to adjust the sub second hand as it is a bit angled upwards and catching the minute hand stopping the whole movement but before this happened there were some wild deviations. HWGIKE#58 Alarm clock, cooked in hot cleaning fluid and oiled gently. This is a movement so I count it. 🙂 A while ago it tried to fly away one day, it was on my windows sill, we had strong wind the curtain flew like a flag and doing so encouraged my clock to do the same...  went out and ended up on the roof above the entrance door, its door in pieces but the clock itself suffered no damage otherwise. The original glass was already broken when I received it I still have the bottom part in two pieces. The new "glass" is acrylic. It also had a paper in the back in the case inside but it disintegrated, I still have a little bit of  piece of that too.     HWGIKE#59 Durowe 870 / Times M84 This particular instance is a D870, when I saw its worn out contact pin I thought that it must be a design flaw, and here we go: https://17jewels.info/movements/d/durowe/durowe-870/ An incredible movement again where the balance wheel drives the train and has two magnets one for the balance wheel/coil and one for the pallet. The magnet for the pallet is basically the "draw" one direction. The coil is about 1.8kOhm and one end is in contact with the main plate and the other end is soldered to a contact pin which is insulated by the means of putting it into a jewel and this contact pin is rubbing against a wire getting the energy/impulse as it is passing. Behind the contact pin there is an "impulse jewel" not sure why is it there... the wire seems to hit the impulse jewel first then the contact pin but maybe it is there only for insulation purposes? I was almost certain that the screw holding down the battery - (minus) clamp had no insulation washer.. i only noticed the green stuff around it coming from battery leakage... anyway the + and - had a shortcut which took me a while to realize.. had to fabricate one insulating washer on my own. The jewel settings were dirty but not it is all cleaned and oiled. The contact pin might work for a while but I am sure it has a short life. It is a front loader the whole thing is held together by the case so it is not possible to regulate it without putting it all together and taking the movement out of the case again, very inconvenient. A wonderful movement but not made for eternity only for the consumer market.
