hi everybody
i have a watch maybe from the sixties which works perfectly face up keeping very good time.  unfortunately
when you turn it upside down it stops immediately. fault suggestions would very much appreciated
regards to all
roger
Hi roger, first de-mag the watch and test again.  Then check the end shake on the balance, which should be perceptible but not excessive. The balance should be perfectly free in all positions. Check roller to fork clearance face down. You will have to systematically go through the motions. Sorry, but without seeing the watch it is difficult to be specific, for me anyway. Take OH`s advice.
hi.
thanks for the responses. the movement is a raymond dodane  RD344-2 apparently
inspired in conjuction with the swiss.  manufactured in france in besançon 1968-1972.
i took the back off and with the watch face up the balance amplitude is no more than
90 degrees at best. the watch is called solo which i suspect went defunct. the watch is
only 32mm diameter 17 jewel.  i am very suprised it keeps very good time.  this in its day
was quite a quality watch with 2 hallmarks for gold plated.
i will get the watch serviced. again thanks for input
best wishes to all
roger
    • You will still be looking for a balance complete I’m afraid, this is the balance staff, balance wheel and hairspring in one package. Hairspring and the balance wheel are matched in the factory. Whilst we can change a balance staff the hairspring and balance wheel stay together.   Tom
    • The hairspring end has come adrift from the small terminal barrel.  I have tried to remove the taper pin to relocate it, but the task is beyond my skill set, eyes, hands and being in my 70s, probably beyond my life expectancy.  It is not too badly mangled on the end.  On the ebay offer, that really is a bit on the rich side.  I'll keep looking, maybe a good hairspring will turn up with a shot balance staff. As for time spent on knees.  I made up one of these from 3M magnetic tape and a piece of wood.  It works well for magnetic parts. Other things I have suffered with.  I found lubricants so very expensive that I bought some very small syringes and tiny needles.  I just decant a drop into my oiling pots when I start a movement and the remainder keeps really well in the syringes. Finally identifying the correct screw for the part led me to make up the board in the final pic.   Thanks for the info. Kind regards   Chris
    • Yes that's the type @watchweasol is referring too but I don't like them as you don't get any feel to what's happening.
    • Hi there Stoller,   Caliber is generally stamped under the balance or thereabouts.  Caliber can't neccessarily be identified by bridge layout. Regs
    • Unless you've got any better suggestions Isn't that what this forum is about? It still depends what state the balance is in to start with. Edit You see, it's things like this that really wind me up and make me wonder if it's worth even sticking around, think I'll say goodnight and keep well
