Good (insert time here) everyone!
     I am relatively new to the world of clockwork repair and maintenence, but have done delicate metalwork, mechanism cleaning, and enjoy fixing things. Just recently, my sister brought home her boyfriends late great grandmothers singing bird in cage automata. For those of you who dont completely know or understand what it is, its basically a spring driven mechanism using bellows and a variable organ pipe to make bird sounds and move a little birdie around and "sing" (Example of singing bird mechanism working).
     His aunt wants it to be operational again, and after opening it up (not yet taking much apart) I have come to the conclusion that it could just use a good cleaning and oiling. But, my question is, what kind of oil should I use and how should I apply it? I don't have any fancy oils except for a bottle of valve oil for my trumpet at my current disposal, but I would like to buy some decent clockwork oil for this project and a sankyo music box repair I have waiting.
     Note: come to find out while writing this, it was made by eschle reuge I'm Germany, probably around the 50's or 40's.
Back in 46 I remember my Grandma had one with two birds in it. It had a "penny in the slot" mechanism. She sold loads of things to clear out after being bombed out in the blitz and it went for five shillings !!.
  • 1 year later...
  • 3 years later...
Good day, I have just acquired one of these as well, a double bird.  But the original bellows are past their used by date.  Is there a way to replace the latex or silicone "drums" as the rest is in working order
I am sooo happy this post started! I have been hoping it would. I have a clockwork toy collection and right now need help with a 30s loop-the-loop toy with  a decreasing strength issue. I would have postd but last week my sister stepped on the two-guys-in-a-cart vehicle that travels the loops and I can't find one wheel. Will pay attention here instead.
  • Similar Content
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
