To tight ETA type of Center Wheel/Cannon Pinion
Hello Mates!
Im working on an ETA 2783, and suspect that the canon pinion is to tight against the lower wheel.
So I have to make it a little bit more loose...
Has anybody done this befor?
And how it the best way to do this?
Thanks   A
I used to hate this type, the only satisfactory way I found was a tiny drop of oil between the wheel and where the cannon fits in. I have even found them to tighten up after cleaning. Don’t try and punch it tight because it will make thigs worse.
The only other thing would be try and seek a replacement.
O..... thanks  at lot for you kind words oldhippy!!  I was thinking im going nuts, that was just was happening.....just tok it out from cleaning, and this was stiff as h....... I thought maybe  I had done something wrong when dismounting.
Okay  I find a new one...
Thanks a lot, and a good friday to you
10 minutes ago, nickelsilver said:
Use a heavy oil or grease there. D5, HP 1000, Jisma. It must be lubricated.
I have tried to lubricate, but no change, is is stiff, and the watch have very poorly apmlitude
I see this tip on a vid just recently. To check if a  cannon pinion is too tight run the watch and if when you turn the crown to reverse the hands the second hand should still run free if it stops then the canon is too tight.
 Friction between canon pinion and it's driver is a neccessity for power transfer.
Tightness and sliding action between the two comes to play when setting the hands only.
Thightness between canon pinion and reduction gear can affect amplitude.
  • Similar Content
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
