A friend asked me last year if I could fix her 9kt gold Adaux cocktail watch that had been left to her by her mother. A quick look soon diagnosed a broken balance staff, so the Internet hunt began. The first complete balance that was sold as "new" had both pivot broken off, but luckily a refund was made quickly. The second came from the states and was NOS still in original blister pack.
The movement is an FHF 60 and is slightly smaller than a new UK penny so this was going to be a challenge because of the size. I duly set about about dismantling it after dressing my smallest screwdrivers to ensure perfect fit with the tiny screws, particularly the one that hold on the cap jewels. The movement was thoroughly cleaned, lubed, reassembled and timed using my timegrapher. I am well pleased with the timekeeping.
I refinished the case and crystal, installed the movement and fitted a new strap. It certainly made a change from working on these "massive"gents watches!
Nice one Geo, and that's a really pretty little Audax.
I actually started out with ladies watches partly because they tend to be so much cheaper than similar quality gents watches, but also because I figured that if I could get to grips with the smaller movements then the bigger jobs would be easy. I still really enjoy working on them and it's nice to see others doing the same.
Nice one George.
I have a couple of ladies watches on the back burner that I have bottled out of for a while but yet may "man up" to the job after seeing your excellent work.  Now I can actually see what I am doing with the scope it may be ok, but they are really small.
There are a couple of definitive factors in this pursuit of watch repair that seems to be essential - patience and contemplation.  They do bring rewards bordering on the esoteric though.
Cheers,  Vic
Well done Geo, nice job !
just wondered what size eyeglass you used ?  as I have a couple of similar watches to do but I've been saving them for the right moment as I'm a little concerned about the size,
Thanks for the comments guys.
Most of the work was done with my 3.5x visor. Lubrication was done with 10x loupe.
Very nice job Geo! Not your average run of the mill overhaul. What do you mean by "dressing" your screw drivers? I see that the cap screws are very small and I just had the same problem on a similar screw where my driver tip has a little curve in it that causes the screwdriver to slip. I know you guys have done a whole  long thread on this topic of screwdrivers. Do you mean you sharpen them up with a stone?
JC
Edited by noirrac1j
JC
Hi Joe, that is exactly what I mean. I use a fine, and extra fine diamond slips to keep my drivers in perfect condition. Making sure that your screwdrivers are both the correct fit and sharp is something overlooked by some folk.
    • By the way, I opened my watch, looked under a magnifying glass, there is simply no grease, the screws are without traces, the slots are intact.I think it's just a matter of maintenance.there are no rotor marks on the body. And to remove the strap from yours, just press on the 1st side,and slightly move the strap, then on the other side and it will come off.
    • Hi My name is Chris. Just started trying to learn about watch and clock repair as a result of repairing my fathers old 1890s police station clock (about a year ago). The clock was Ok, but having graduated to pocket watches and then wrist watches, despite the really excellent stuff on Youtube, I am struggling a bit.  As a retired engineer, I find the engineering exquisite, but a bit on the fiddly side.  I have done a few practice watches with a little success but failed a few, but have had success with Seiko 7005s, 7009s etc, but have just attempted a citizen 5430.  Nightmare.  My wife thought I had found religion as I spent so much time on my knees with my eyes to the floor looking for springs.  Got through that and found that the balance is shot.  Trying to source one or something that will fit from the citizen range has me totally perplexed.  Tried Ebay, Cousins etc without luck.  Any advice as to alternatives that will fit or alternative sources would be gratefully received.
    • I have only been a member for six years & I have found this a very friendly forum although I don’t have anything to do with watches not because I don’t like watches but because I have gout in both hands so my dexterity isn’t very good, I restore torsion clocks & occasionally other antique clocks also at 72 my eyes are not what they used to be, that is why I only post on the clock forum & the lathe forum mostly . As others have said Mark it is much appreciated that  you are willing & able to do this. very many Thanks Dell
    • Ah, this is brilliant, thank you very much!
