Thanks, not that much of a savings on a per jar price over the Amazon ones I got which were $38 for 24 or about $1.60/jar.
What model is it and what spring did you get from Cousins as it looks like a CN2110 which Cousins don't show a click for?
I've never done one of these, what is the correct method?
You want to make sure it doesn't show. Have you tried all the glass panels when the case is all together because you don't want to break any.
There was just 1 hole in the case and only 1 way it could be placed. I have worked on a Seiko that had a similar spring with 2 holes in the case under the bezel and that one could take the same spring in 2 different orientations - I guess it was symmetrical anyway…. That Seiko also had a much tighter grip on the bezel and it felt a lot less likely it could get pulled off. It was however a much harder job getting that bezel back on
