My first balance staff!
Finally got around to cutting my first successful balance staff. It is for a 201 caliber Jaeger-LeCoultre 8-Day aircraft clock. In fact this is the same clock that got me interested in watch repair as a hobby.
The first attempt resulted in a pivot being cut off while I was finishing it up, it was complete except for the finishing on the last pivot and it just disappeared. That was with wire rod. Second attempt was with blued wire rod, which I should have been using to begin with. Took my time and ended up with a usable staff.
Installed on the balance assembly and it worked!!
  • Like 5
Finishing the pivot and breaking and flying into no man’s land is common when you start out making staffs. You have achieved what many watch repairs can’t undertake. Congratulations in repairing your aircraft clock.
Jnash there are videos on Youtube about sharpening gravers. It takes practice. When you have achieved that, practice on some brass rod first before steel, as you know brass is softer. I always used a block arkansas stone with a little oil to sharpen my old gravers. Tungsten steel gravers are what I used.
Thanks for the nice words, cutting a balance staff was one of the things that I really wanted to do successfully. I hope this one is not a fluke because I have another 8 day aircraft clock that needs a balance staff also.
I started using HSS gravers but a local watchmaker let me borrow a set of Barkus carbide gravers. I noticed a big difference in cutting, the Barkus cut the blue steel easily.
He told me I could use them as long as I wanted but they were not for sale, now I know why. They were a pleasure to use.
Cannot wait till I have enough time off work to give it another try. Yep, this is addicting!
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
