Making a Balance Staff
Need to make a balance staff for a European picket watch. The old staff had both pivots broken off. First I disassembled the watch and removed the balance staff. Removing the roller table was the hardest part because it was a Three arm balance and my Magic Roller Remover would not work so I used the scissor type.6747fe43a99bd188eacf952d9fef8dac.jpge7e75d9c69e9a769a9ad6711e9c6b4a6.jpg1fa88274beaa1d13932d30eec2514bed.jpgc078f7e520c6a346dfadcaff67cec649.jpg30f532e8ae4870da44c7cbcaa0281ed8.jpg1e2a163391ea846c35b2b298187f5b07.jpg844d0cfbd16fab2a941d595c66400080.jpg
I then determined the widest diameter of the balance staff and found a 2.0 mm piece of Blued Steel. I cut off 1 inch and sized the collet, and inserted in into my Boley Leinen Lathe. I then started to cut the Balance and Hairspring side by first using the old staff as a guide and marking the piece of steel with my carbide graver.84d1245e54d14e9c32e366e831d56e88.jpga8d59714009b2c8e9837c7d0a23a9576.jpg
I started cutting down the first diameter where the balance fits and simply cut and measure until it was snug but still room to stake it in place. I then cut the hairspring diameter next and fix and cut repeatedly until it was snug. I used a special gauge to measure as I went along. Once the part fit was good I worked on the pivot with the graver until I got it down to around 0.2 mm and then used a stone to get it to around 0.14. The rest I plan to do on a Jacot tool.0674a45da0908e5666cce3fe60dacaea.jpg5f5da6c0d5a8c8836f329b4007570fd4.jpg974ed69f2161befa35058fb02420bf8f.jpg
I then flipped the part around with a different collet and started working the Roller Table side using the same technique. I Amos finished off the plate where both the rolled table on one side and the balance on the other side rest.7f9288040022be85fb24dd8435190d3d.jpg
Slight error in the description. I left the full part in and started working on the roller table side before cutting off the part and flipping it around...saves time.fef5e1e9bedb5099cc57df61d48dd29c.jpge35b6f93179d1155af32162d51002e0d.jpg69dcc763d9f12d137ec285e3e6e5a2d8.jpg73865aa95c3ce5477a81ab5860cefa62.jpgae5f5dd2ca1ac1eaceaf541f66d0e1c0.jpg
I worked on the other pivot as well and got it down to 0.14 with a graver and then a stone...on the Lathe. The final product looked great. I am waiting for a set of vintage pin gauges to get the pivot size exact. Will finish it off next week.bae231293c9eefa9bb05910589d5ce6d.jpg13be0555c60fc6945650f2f963450b71.jpg
  • Like 8
More progress. As well, made a video on how to use Jewel Hole Gauges. So I staked the balance wheel onto the newly made balance staff, friction fit, and it fit really well. Very pleased . I then used the jewel hole gauges to determine the hole size and this the pivot size. Turned out to be 0.10. Now I need to burnish the pivots to that size, fit the part in the movement and once fit perfectly, I will add the rolled table and the hairspring.
Also lined up the impulse jewel to the center of two arms and then drew the line straight from the jewel to the pallet fork pivot then placed the hairspring on the balance loosely to align with stud; while the impulse was perfectly centred with between the banking pins.
    • Yeah I thought so too. It seems to be original since the paint is the same. My theory is, that it is either some sort of an attachment point for an indexing assembly or for a collet closer like this one.
    • Hi, yeah I have done a lot of researching there
    • That was the intial reason I used mine the one time, timegrapher wouldn't pick up a signal, but it turned out to be something else. For fairly rare events like this, you're probably better off using Nicklesilver's method, or use an accurate pocket watch to match the oscillations up to. I think the tool is best suited to folk that time balances regularly, as would have been the case years ago. Maybe for small companies that let out their hairspring timing services, that didn't have the movement to work with. At the end of the day you already have the perfect timing device....the actual movement. The tool's convenience merely saves you the time and effort of unpinning and repinning the hairspring to the stud a few times to get it right.  Providing a " Prior Idiot " hasn't fitted incorrect train wheels 😄
    • If you restaff the balance correctly, there should be no need to repoise the wheel, unless it was messed with by a previous watchmaker. Here is an experiment to try that will explain my findings. Remove the balance from a correctly running watch that is marked "adjusted to 5 or 6 positions" or however many they claim. Place it on your poising tool, and you will find that it is out of poise. But, being out of poise, it has been adjusted for positional adjustments, to average the 5 or 10 seconds a day. It seems like you would want the wheel to be perfectly weighted all around, but it might run better a little heavier CU at the 4:30 position on the wheel. HERE is a good article that can explain it better than me. I also see a large amount of bad repairs, back when it was a cutthroat occupation. So if someone did re-poise a balance before you, you might have to do it again to correct it for positional accuracy. But at that point, its a sunken cost fallacy, as it will take a long time to make adjustments to 6 positional accuracy, so you might be better off finding an unmolested replacement.
