Guys just wondering if the bottom post can be removed? I would like to be able to use some threads dies also with this press.
If the bottom post can be removed which direction should it be removed?
Thanks
Tom
Used some Liquid Wrench and a rod and hammer success, the c-clamp didn't budge the pressed in stub.
It took major force to remove the bottom die holder.
    • Thank you @Mark. I only became a Patreon subscriber 5 or 6 months ago, but I draw so much value here. If you come up with future contribution or support opportunities, I will be on board.
