 Verge PW Made by Broadhurst Widness. Silver inside another outer silver case. Hallmarked. Fusee and chain OK Probably around early 1800`also, Balance problem and HS broken, had a hard time, no hands nor crystal. Paddles look OK. Must get started and somehow make this tick !!. Also given  an early English lever. Silver. D. Blunt Northampton.  Dismantled. Repaired the mainspring at the arbor, Chain and fusee OK. HS missing!! Battling onwards. More later and hopefully Photo`s when grandson has time.
Edited by ecodec
More info
12 hours ago, oldhippy said:
Keep us in touch with photos. I certainly would like to see both.
OK. OH. Got the D. Blunt Lever PW dismantled today and all ready for a through clean then close examination. Leaving the Verge watch for the moment. More later.
    • It's not really shown here , but the blade flips over, so it faces the other way. The knob and threaded case holder then pushes the caseback seam into the blade. Once the blade starts to penetrate into it, the lever and blade are lifted , which should hopefully pop the back off. A lot of fashion style cases have very tight seams and need a sharp blade to start separating them.  Don't buy the cheaper plastic versions of this tool, the posts with the pins through for blade holder break easily if the apply extra force to blade.
    • You will still be looking for a balance complete I’m afraid, this is the balance staff, balance wheel and hairspring in one package. Hairspring and the balance wheel are matched in the factory. Whilst we can change a balance staff the hairspring and balance wheel stay together.   Tom
    • The hairspring end has come adrift from the small terminal barrel.  I have tried to remove the taper pin to relocate it, but the task is beyond my skill set, eyes, hands and being in my 70s, probably beyond my life expectancy.  It is not too badly mangled on the end.  On the ebay offer, that really is a bit on the rich side.  I'll keep looking, maybe a good hairspring will turn up with a shot balance staff. As for time spent on knees.  I made up one of these from 3M magnetic tape and a piece of wood.  It works well for magnetic parts. Other things I have suffered with.  I found lubricants so very expensive that I bought some very small syringes and tiny needles.  I just decant a drop into my oiling pots when I start a movement and the remainder keeps really well in the syringes. Finally identifying the correct screw for the part led me to make up the board in the final pic.   Thanks for the info. Kind regards   Chris
    • Yes that's the type @watchweasol is referring too but I don't like them as you don't get any feel to what's happening.
    • Hi there Stoller,   Caliber is generally stamped under the balance or thereabouts.  Caliber can't neccessarily be identified by bridge layout. Regs
