Hi
I'm struggling with this piece. Its  Seiko 2205 with 28800 bph. It's has been rebuild from scratch and it's working fine for some time then the balance spring gets magically magnetized( no obvious source of magnetic field) and I have no clue how to demagnetized it. I have demagnetizer as per photo and while it does the job on tweezers and screwdrivers i had no success in demagnetizing this balance/spring. I have already run 3 sets of new balance wheel and spring but it tragically uneconomical. Any hints how to demagnetize it without spending a fortune on pro demagnetizer. Maybe somebody here would be kind enough to demagnetize it for a little fee. Thanx for any hints
Just to clarify, have you demagnetised the watch as a whole? If not, another component of the movement may be magnetising the spring
Sent from my Redmi 4X using Tapatalk
In regards to " no obvious source of magnetic field" and to make sure your assumption is correct.following demagnetisation , I would put the watch in any metal box fully closed, this box will absorbe any force carrying photons ie, prevents magnetic field affecting inside the box. The source of the majic is there, it has not been identified.
Regarrds
Hi
Thanx for your answers. Yes i have demanetized the whole watch, while it was unwind. Last time it happened i ended up buying new balance assembly which worked for 2 months then watch was left unwind for maybe a month and while wound it started to gain about 5 sec in a minute. i left it to loose power, demagnetized  it and with no luck. Maybe i should mention that the balance spring is super thin and tiny so i'd assume it would be more prone to magnetism problem.
As of the box would empty  metal food can do the job?
    • It's not really shown here , but the blade flips over, so it faces the other way. The knob and threaded case holder then pushes the caseback seam into the blade. Once the blade starts to penetrate into it, the lever and blade are lifted , which should hopefully pop the back off. A lot of fashion style cases have very tight seams and need a sharp blade to start separating them.  Don't buy the cheaper plastic versions of this tool, the posts with the pins through for blade holder break easily if the apply extra force to blade.
    • You will still be looking for a balance complete I’m afraid, this is the balance staff, balance wheel and hairspring in one package. Hairspring and the balance wheel are matched in the factory. Whilst we can change a balance staff the hairspring and balance wheel stay together.   Tom
    • The hairspring end has come adrift from the small terminal barrel.  I have tried to remove the taper pin to relocate it, but the task is beyond my skill set, eyes, hands and being in my 70s, probably beyond my life expectancy.  It is not too badly mangled on the end.  On the ebay offer, that really is a bit on the rich side.  I'll keep looking, maybe a good hairspring will turn up with a shot balance staff. As for time spent on knees.  I made up one of these from 3M magnetic tape and a piece of wood.  It works well for magnetic parts. Other things I have suffered with.  I found lubricants so very expensive that I bought some very small syringes and tiny needles.  I just decant a drop into my oiling pots when I start a movement and the remainder keeps really well in the syringes. Finally identifying the correct screw for the part led me to make up the board in the final pic.   Thanks for the info. Kind regards   Chris
    • Yes that's the type @watchweasol is referring too but I don't like them as you don't get any feel to what's happening.
    • Hi there Stoller,   Caliber is generally stamped under the balance or thereabouts.  Caliber can't neccessarily be identified by bridge layout. Regs
