I was impressed with the project, workmanship and video production and thought you guys might enjoy it.    A neat piece work with a rather complex 'secret' stepped lock - hang in there to the end to see how it operates.
Fantastic piece of work and craftsmanship. But I'm a bit puzzled what's the idea of it? For safekeeping? Sure the box on its own would be heavy, but still transportable. Next, chances are that the value of the box is higher than its contents. Is it a show-piece to show off his excellent skills? Or is it to admire ......... because it is for sure admirable ........ !
Another possibility is a combination of all the above :)
Edited by Endeavor
I have no idea, possibly a commission?   art?  reminiscent of historical creations back when a lock box really mattered?  I don't think I'd set out to build one but in a way its lot like a finely made, expensive mechanical watch;  you don't really need one to tell time just like you don't need that box to keep things secure , but you like them just because they are such a mechanical marvels of craftsmen,  an achievement of the human spirit and all.  Best I can come up with anyway :)
Edited by measuretwice
    • No mate. Sorry if that offends you! Also please don’t take threads off-topic. I thank you sir.
    • Thanks Mark I have uBlock Origin Lite add-on for my Windows Chrome browser, so I've never seen a single ad on this site ! It also removes all adds from Youtube - I couldn't bear to watch it without uBlock
