Urgos Grandfather Clock
Folkvisor
Hi All
I haven't been here for a while.
I'm working on an Urgos Grandfather Clock. The movement seems to be working fine but the clock isn't free-standing. It's in the middle of a China cabinet and there are no side access panels.
I am tempted to MAKE some with a chainsaw but, unfortunately, the owner doesn't like the idea.
Does anyone have any experience with such creatures?
Dave
Thank you for your answer. Yes it's a modern movement - about 30 years old.
I got it out - took almost an hour. Putting it back in will be even more of a challenge I think. It will only go out the back. I'm hoping I'll be able to fix the dial before putting it back in.
I'm just hoping everything will line up for the chime hammers. I marked everything before removing the movement but it doesn't seem to matter much. I think it's just a kind of hit and miss thing.
But after cleaning and oiling the clock works.
I got it in and it works. It was a LOT easier when I found out it came out the front of the case!!! After doing all kinds of other crap...
Anyway, it's in and working.
But I had a nice level clock shelf for it and it is now on a floor that isn't level so...whatever...
Thank you for your comments.
I found this to be necessary, if you want to find out more about Longcase clocks.
White Dial Clocks: The Complete Guide by Brian Loomes. Any book on clocks by Brian is worth every penny. Watch and clock makers of the world vol 1 and 2 are helpful in dating, comes in very handy if you  have to value clocks but very handy as reference books. Anything by Laurie Penman is worth having. Some of the books I had were very old must have been from around 1900 all out of print. I can write up for you how I would undertake repairing a longcase clock, if that would help you. Watch and clock supplies tend to stock more of the popular books.
I forgot these mags have a fantastic amount of information.
http://www.clocksmagazine.com/
I can second Oldhippy's recommendation of the clocks magazine.
I have a current subscription and it has some real gold in it, also if you are into social media Clocks Magazine also has a facebook group, but I tried to avoid Facebook myself even though I have an account
I am working on another Grandfather Clock.
I think it should come out the front if I can loosen - and later remove - the screws holding it on the saddle to move it back about 1/4 inch so the wooden face-plate can slide down and out. Taking the saddle off won't give it enough room to slide out and it is very awkward to get at it. There are also 2 screws in 2 brackets holding the movement in place on the pendulum side that need to be removed but I'm thinking they can be loosened and left in place until I can see my way clear to take the movement out.
I see no other way to do this safely.
Do you have any advice regarding my idea(s)?
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
