Anyone got one of these lathes??
Lenj
That looks like Unimat 1. If it is they are only good for wood work. The Unimat 6 is for metal. For the price of the Unimat 6 you should be able to get hold of a Unimat 3 which is very good for clock pivots. For watch work you need a watchmakers lathe.
I would suggest that this lathe would be suitable for lightweight model making.  It is configured for metal cutting, but I would question the accuracy of both the three jaw chuck and tailstock.  Diametrical run out and the smallest diameter the chuck will hold are both unlikely to be suitable for watch work.
It may be if some use for larger clock parts, but if you want a lathe for working on microscopic watch pivots you would be advised to pick up a quality second hand watchmakers lathe.
Hiya, Thanks for getting back to me and the info, I am glad I asked.. I will have a lookout for the Unimat 3, I only want it for clocks pivots, I can't see to do that fine a work on watches..
I bought a box of carriage clock bits of the Bay all mixed up, I managed to fit them all together, 2 very nice cases, 3 movements. One was a Charles Frodsham the barrel is shot and I do mean shot....and had a lovely repair done to it, photo attached if interested, also photo of the pivot I need to repair. And one more case to fixup but that needs a lot of work..
Thanks again Len
IMG_8044.thumb.JPG.d6cf81f895832d583d331480aaef92df.JPGIMG_8041.thumb.JPG.1f21f9e2a6c516f20d51ba604f305e51.JPGIMG_8037.thumb.JPG.b67d3f0c83dce8ba005258258652c95c.JPG
Definitely inexpensive and meant to turn metal not wood. At least if you believe the product specifications. So you could purchase one from Amazon but more important you can look at the reviews. The phrase you get what you pay for definitely implies here and it looks like you're probably paying too much.
https://www.amazon.com/Signswise-Motorized-Woodworking-Education-Modelmaking/dp/B00UL3J81S#customerReviews
Then here are some ideas for re-pivoting. Even though it's in the watch repair section there isn't any reason why you couldn't scale them up in size to do clocks. The only problem is there are either accessories for a lathe or you really need a lathe to make these.
https://www.watchrepairtalk.com/topic/4474-look-at-that-a-new-toy-diy-pivot-drill/
5 hours ago, Lenj said:
Well I had a look at the Ulimat 3 and that is twice the cost of the one above.
If you see a U3 for 2x that, pounce....but be careful, its likely missing components.   I get that its what its worth to you that matters, but I'm challenged to see how a machine selling for $150 could remotely be satisfactory machining anything accurately and U3's are really nice bench top setup, Austrian made and made well.  Spending $150, getting frustrated and tossing isn't a good outcome either....whereas with U3 it still be worth what you paid for it :)   Currently with 22 lathes from watchmakers to a 5200 lb DSG, I'm big big believer in carefully buying used quality machines as the way to get the best bang for the buck.
Yes you do get what you pay for that's for sure...Thanks for the link, that looks like a good project..
Len
Hi, thanks for the info..as I said yes you do get what you pay for, but I can't justify that sort of money to do a couple of pivots, I like the home made jobby, that look fun to make..
Len
  • 5 years later...
Hi the best way is using a lathe and drill attachment or a chuck in the tail stock. I made a drilling flag that fits  the tool post and the broken end runs in the guide and the drill is placed through the guide to drill the arbour, I have also used a vertical drill to do the same job with no problem.
  • Similar Content
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
