Trying my first watch build and cant figure out how to release the stem on a Sellita SW200-1 movement.  Reference material from Sellita shows a diagram of a bridge cutout and a part, I believe was the setting lever but am not sure of the correct way to remove the stem.  Any help would be appreciated
Use the largest tip screw driver which gets in the oval hole. The tip is be wider than diametet of release button and enters cross to the STEM AXIS, a shoulder is provided inside the hole to stop the screwdriver tip from insertion deeper in. Pushed in down to the shoulder which is enough to leave the stem free to be taken out. If not clear let m know to hand draw you a sketch showing what I say.
Regqrds joe
Yes, thanks to OH , the picture shows the push button.
The hole as viewed from top is not circulare but parabollic.
The screwdriver blade should be wider than diameter of  the button, so not to enter the button hole, rather enter the parobollic hole only and go down as far as the parrabolla hole provides depth,  the shoulder inside keeps the screwdriver from entering button hole only if the screwdriver blade is wider than button hole.
Sorry to post a n00b question, but it's somewhat related...
After you put the hands back on the watch how do you remove the stem (in order to put it in the case)? Is it ok to put the face down on the Movement Cushion Pad, I'm worried that doing that may bend the hands or something?
You risk damaging the dial plate too. Dial should not be subjected to any stress.
If your movement holder blocks access to the back of the movement , perhaps tranferring the movement on another holder which allows such access is considerable.
I have managed sliding  the movement in the case at oblique angle,  with crown removed from the stem. Once movement is in place in the case, remove the stem to tighten the crown back on stem and reinsert in the movement. Easier done than said.
Picture of the predicament you got in helps.
Regards joe
    • It's not really shown here , but the blade flips over, so it faces the other way. The knob and threaded case holder then pushes the caseback seam into the blade. Once the blade starts to penetrate into it, the lever and blade are lifted , which should hopefully pop the back off. A lot of fashion style cases have very tight seams and need a sharp blade to start separating them.  Don't buy the cheaper plastic versions of this tool, the posts with the pins through for blade holder break easily if the apply extra force to blade.
    • You will still be looking for a balance complete I’m afraid, this is the balance staff, balance wheel and hairspring in one package. Hairspring and the balance wheel are matched in the factory. Whilst we can change a balance staff the hairspring and balance wheel stay together.   Tom
    • The hairspring end has come adrift from the small terminal barrel.  I have tried to remove the taper pin to relocate it, but the task is beyond my skill set, eyes, hands and being in my 70s, probably beyond my life expectancy.  It is not too badly mangled on the end.  On the ebay offer, that really is a bit on the rich side.  I'll keep looking, maybe a good hairspring will turn up with a shot balance staff. As for time spent on knees.  I made up one of these from 3M magnetic tape and a piece of wood.  It works well for magnetic parts. Other things I have suffered with.  I found lubricants so very expensive that I bought some very small syringes and tiny needles.  I just decant a drop into my oiling pots when I start a movement and the remainder keeps really well in the syringes. Finally identifying the correct screw for the part led me to make up the board in the final pic.   Thanks for the info. Kind regards   Chris
    • Yes that's the type @watchweasol is referring too but I don't like them as you don't get any feel to what's happening.
    • Hi there Stoller,   Caliber is generally stamped under the balance or thereabouts.  Caliber can't neccessarily be identified by bridge layout. Regs
